Size: 6.75 x 24
Design Span (L): 19.75 ft.
Clear Span: 19.50 ft.
Total Span: 20.00 ft.
Live Load: 90 plf
Dead Load: 10 plf
Selfweight: 750.1 lbs
Dist. Selfweight: 37.98 plf
Total Weight: 759.6 lbs
CV Volume Factor 0.913b - - - - -
Beam Design 2021A478
8/28/2021 1
b = 6.750 in.
d = 24.000 in.
A = 6.750 x 24.000 = 162.00 in.2
Sx = (6.750)(24.000)2/6 = 648.00 in.3
Sy = (6.750)2(24.000)/6 = 182.25 in.3
Ix = (6.750)(24.000)3/12 = 7776.00 in.4
Iy = (6.750)3(24.000)/12 = 615.09 in.4
8/28/2021 2
Volumetotal = N[A x (L + lb)] = 1 x [162.00 x (237.00 + 3)] x (12 in./ft.)3 = 22.50 ft3
Volumespan = N[A x L] = 1 x [162.00 x 237.00] x (12 in./ft.)3 = 22.22 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 22.50 = 759.6 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 22.22 = 750.1 lbs
Distributed Self Weight (ws) = = 37.98 plf
90 plf
10 plf
  ws = 37.98 plf
19.75 ft.
19.50 ft.
1379.81 lbs
1379.81 lbs
8/28/2021 3
CV = = 0.913
CV = 0.913 < CL = 1
Fbx' = (2400)(1.15)(1)(1)(0.913) = 2520.6 psi
fb = = 124.6 psi
 fb = 124.6 psi < Fbx' = 2520.6 psi  (CSI = 0.05)   ➜  OK
8/28/2021 4
fv* = = 10.06 psi
 fv* = 10.06 psi < Fvx' = 304.75 psi  (CSI = 0.03)   ➜  OK
fv = = 12.62 psi
 fv = 12.62 psi < Fvx' = 304.75 psi  (CSI = 0.04)   ➜  OK
8/28/2021 5
ΔLL = = 0.02 in.
(L/d)LL = 237.00 / 0.02 = 10767
 ΔLL = 0.02 in = L/10767 < L/360   ➜  OK
ΔTL = = 0.03 in.
(L/d)TL = 237.00 / 0.03 = 7023
 ΔTL = 0.03 in = L/7023 < L/240   ➜  OK
fc⊥ = = 68.1 psi
 fc⊥ = 68.1 psi < Fc⊥x' = 650.00 psi  (CSI = 0.10)   ➜  OK
8/28/2021 6
