Beam Design - Laurel Ave Beam 2
Size: 3.125 x 18
Design Span (L): 18.92 ft.
Clear Span: 18.58 ft.
Total Span: 19.25 ft.
Bearing (lb): 4 in.
Selfweight: 249.5 lbs
Dist. Selfweight: 13.19 plf
Total Weight: 253.9 lbs
Beam Design JUAN ARMENTA 21-029
8/17/2021 1
b = 3.125 in.
d = 18.000 in.
A = 3.125 x 18.000 = 56.25 in.2
Sx = (3.125)(18.000)2/6 = 168.75 in.3
Sy = (3.125)2(18.000)/6 = 29.30 in.3
Ix = (3.125)(18.000)3/12 = 1518.75 in.4
Iy = (3.125)3(18.000)/12 = 45.78 in.4
8/17/2021 2
Volumetotal = N[A x (L + lb)] = 1 x [56.25 x (227.02 + 4)] x (12 in./ft.)3 = 7.52 ft3
Volumespan = N[A x L] = 1 x [56.25 x 227.02] x (12 in./ft.)3 = 7.39 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 7.52 = 253.9 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 7.39 = 249.5 lbs
Distributed Self Weight (ws) = = 13.19 plf
  ws = 13.19 plf
18.92 ft.
18.58 ft.
19.25 ft.
1811.43 lbs
1811.43 lbs
8/17/2021 3
fb = = 598.7 psi
 fb = 598.7 psi < Fbx' = 2400.0 psi  (CSI = 0.25)   ➜  OK
8/17/2021 4
fv* = = 39.94 psi
 fv* = 39.94 psi < Fvx' = 265.00 psi  (CSI = 0.15)   ➜  OK
fv = = 47.47 psi
 fv = 47.47 psi < Fvx' = 265.00 psi  (CSI = 0.18)   ➜  OK
8/17/2021 5
ΔLL = = 0.11 in.
(L/d)LL = 227.02 / 0.11 = 2153
 ΔLL = 0.11 in = L/2153 < L/180   ➜  OK
ΔTL = = 0.20 in.
(L/d)TL = 227.02 / 0.20 = 1144
 ΔTL = 0.20 in = L/1144 < L/120   ➜  OK
Ab = b x lb = 3.125 x 4 = 12.50 in2
fc⊥ = = 144.9 psi
 fc⊥ = 144.9 psi < Fc⊥x' = 650.00 psi  (CSI = 0.22)   ➜  OK
8/17/2021 6
