Beam Design - Laurel Ave Beam 2
Size: 5.5 x 18
Design Span (L): 18.92 ft.
Clear Span: 18.58 ft.
Total Span: 19.25 ft.
Bearing (lb): 4 in.
Selfweight: 439.1 lbs
Dist. Selfweight: 23.21 plf
Total Weight: 446.8 lbs
CV Volume Factor 0.964b - - - - -
Beam Design JUAN ARMENTA 21-029
8/17/2021 1
d = 18.000 in.
8/17/2021 2
Volumetotal = N[A x (L + lb)] = 1 x [99.00 x (227.00 + 4)] x (12 in./ft.)3 = 13.23 ft3
Volumespan = N[A x L] = 1 x [99.00 x 227.00] x (12 in./ft.)3 = 13.01 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 13.23 = 446.8 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 13.01 = 439.1 lbs
  ws = 23.21 plf
18.92 ft.
18.58 ft.
19.25 ft.
1907.81 lbs
1907.81 lbs
8/17/2021 3
CV = = 0.964
CV = 0.964 < CL = 1
Fbx' = (2400)(1.00)(1)(1)(0.964) = 2312.4 psi
fb = = 358.2 psi
 fb = 358.2 psi < Fbx' = 2312.4 psi  (CSI = 0.15)   ➜  OK
8/17/2021 4
fv* = = 23.90 psi
 fv* = 23.90 psi < Fvx' = 265.00 psi  (CSI = 0.09)   ➜  OK
fv = = 28.41 psi
 fv = 28.41 psi < Fvx' = 265.00 psi  (CSI = 0.11)   ➜  OK
8/17/2021 5
ΔLL = = 0.06 in.
(L/d)LL = 227.00 / 0.06 = 3791
 ΔLL = 0.06 in = L/3791 < L/180   ➜  OK
ΔTL = = 0.12 in.
(L/d)TL = 227.00 / 0.12 = 1912
 ΔTL = 0.12 in = L/1912 < L/120   ➜  OK
Ab = b x lb = 5.5 x 4 = 22.00 in2
fc⊥ = = 86.7 psi
 fc⊥ = 86.7 psi < Fc⊥x' = 650.00 psi  (CSI = 0.13)   ➜  OK
8/17/2021 6
