Grade: SPF SS
Size: 4 x 8
Design Span (L): 12.75 ft.
Clear Span: 12.50 ft.
Total Span: 13.00 ft.
Selfweight: 65.4 lbs
Dist. Selfweight: 5.13 plf
Total Weight: 66.7 lbs
Beam Design 2021A471
8/17/2021 1
8/17/2021 2
Volumetotal = N[A x (L + lb)] = 1 x [25.38 x (153.00 + 3)] x (12 in./ft.)3 = 2.29 ft3
Volumespan = N[A x L] = 1 x [25.38 x 153.00] x (12 in./ft.)3 = 2.25 ft3
Total Weight (WT) = ρw x Volumetotal = 29.10 x 2.29 = 66.7 lbs
Self Weight (WS) = ρw x Volumespan = 29.10 x 2.25 = 65.4 lbs
Distributed Self Weight (ws) = = 5.13 plf
ws = 5.13 plf
12.75 ft.
12.50 ft.
13.00 ft.
1170.83 lbs
1170.83 lbs
8/17/2021 3
Fbx' = (1250)(1.15)(1)(1)(1)(1.3)(1)(1) = 1868.8 psi
fb = = 1432.5 psi
 fb = 1432.5 psi < Fbx' = 1868.8 psi  (CSI = 0.77)   ➜  OK
8/17/2021 4
fv* = = 61.45 psi
 fv* = 61.45 psi < Fvx' = 155.25 psi  (CSI = 0.40)   ➜  OK
fv = = 67.88 psi
 fv = 67.88 psi < Fvx' = 155.25 psi  (CSI = 0.44)   ➜  OK
8/17/2021 5
ΔLL = = 0.36 in.
(L/d)LL = 153.00 / 0.36 = 429
 ΔLL = 0.36 in = L/429 < L/360   ➜  OK
ΔTL = = 0.64 in.
(L/d)TL = 153.00 / 0.64 = 238
 ΔTL = 0.64 in = L/238 > L/240   ➜  NG
fc⊥ = = 111.5 psi
 fc⊥ = 111.5 psi < Fc⊥x' = 425.00 psi  (CSI = 0.26)   ➜  OK
8/17/2021 6
