Beam Design - Pace Shop Deck Beam
Size: 5.5 x 21
Design Span (L): 19.33 ft.
Clear Span: 18.67 ft.
Total Span: 20.00 ft.
Bearing (lb): 8 in.
Live Load: 600 plf
Dead Load: 225 plf
Selfweight: 523.5 lbs
Dist. Selfweight: 27.08 plf
Total Weight: 541.6 lbs
CV Volume Factor 0.947b - - - - -
Beam Design Jamie Mongoven 5763 Palomino CT 407
8/17/2021 1
d = 21.000 in.
A = 5.500 x 21.000 = 115.50 in.2
Sx = (5.500)(21.000)2/6 = 404.25 in.3
Sy = (5.500)2(21.000)/6 = 105.88 in.3
Ix = (5.500)(21.000)3/12 = 4244.63 in.4
Iy = (5.500)3(21.000)/12 = 291.16 in.4
8/17/2021 2
Volumetotal = N[A x (L + lb)] = 1 x [115.50 x (232.00 + 8)] x (12 in./ft.)3 = 16.04 ft3
Volumespan = N[A x L] = 1 x [115.50 x 232.00] x (12 in./ft.)3 = 15.51 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 16.04 = 541.6 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 15.51 = 523.5 lbs
Distributed Self Weight (ws) = = 27.08 plf
600 plf
225 plf
  ws = 27.08 plf
19.33 ft.
18.67 ft.
8520.65 lbs
8520.65 lbs
8/17/2021 3
CV = = 0.947
CV = 0.947 < CL = 1
Fbx' = (2400)(1.15)(1)(1)(0.947) = 2612.9 psi
fb = = 1181.7 psi
 fb = 1181.7 psi < Fbx' = 2612.9 psi  (CSI = 0.45)   ➜  OK
8/17/2021 4
fv* = = 87.60 psi
 fv* = 87.60 psi < Fvx' = 304.75 psi  (CSI = 0.29)   ➜  OK
fv = = 106.97 psi
 fv = 106.97 psi < Fvx' = 304.75 psi  (CSI = 0.35)   ➜  OK
8/17/2021 5
ΔLL = = 0.25 in.
(L/d)LL = 232.00 / 0.25 = 940
 ΔLL = 0.25 in = L/940 < L/360   ➜  OK
ΔTL = = 0.35 in.
(L/d)TL = 232.00 / 0.35 = 662
 ΔTL = 0.35 in = L/662 < L/240   ➜  OK
Ab = b x lb = 5.5 x 8 = 44.00 in2
fc⊥ = = 193.7 psi
 fc⊥ = 193.7 psi < Fc⊥x' = 650.00 psi  (CSI = 0.30)   ➜  OK
8/17/2021 6
