Size: 5.5 x 6
Design Span (L): 7.75 ft.
Clear Span: 7.50 ft.
Total Span: 8.00 ft.
Live Load: 320 plf
Dead Load: 80 plf
Selfweight: 63.0 lbs
Dist. Selfweight: 8.13 plf
Total Weight: 65.0 lbs
Beam Design 2021A468
8/15/2021 1
d = 6.000 in.
A = 5.500 x 6.000 = 33.00 in.2
Sx = (5.500)(6.000)2/6 = 33.00 in.3
Sy = (5.500)2(6.000)/6 = 30.25 in.3
Ix = (5.500)(6.000)3/12 = 99.00 in.4
Iy = (5.500)3(6.000)/12 = 83.19 in.4
8/15/2021 2
Volumetotal = N[A x (L + lb)] = 1 x [33.00 x (93.00 + 3)] x (12 in./ft.)3 = 1.83 ft3
Volumespan = N[A x L] = 1 x [33.00 x 93.00] x (12 in./ft.)3 = 1.78 ft3
Total Weight (WT) = ρw x Volumetotal = 35.47 x 1.83 = 65.0 lbs
Self Weight (WS) = ρw x Volumespan = 35.47 x 1.78 = 63.0 lbs
Distributed Self Weight (ws) = = 8.13 plf
320 plf
80 plf
  ws = 8.13 plf
7.75 ft.
7.50 ft.
1632.51 lbs
1632.51 lbs
8/15/2021 3
fb = = 1114.2 psi
 fb = 1114.2 psi < Fbx' = 2208.0 psi  (CSI = 0.50)   ➜  OK
8/15/2021 4
fv* = = 62.61 psi
 fv* = 62.61 psi < Fvx' = 266.66 psi  (CSI = 0.23)   ➜  OK
fv = = 71.89 psi
 fv = 71.89 psi < Fvx' = 266.66 psi  (CSI = 0.27)   ➜  OK
8/15/2021 5
ΔLL = = 0.17 in.
(L/d)LL = 93.00 / 0.17 = 531
 ΔLL = 0.17 in = L/531 < L/240   ➜  OK
ΔTL = = 0.22 in.
(L/d)TL = 93.00 / 0.22 = 417
 ΔTL = 0.22 in = L/417 < L/180   ➜  OK
fc⊥ = = 98.9 psi
 fc⊥ = 98.9 psi < Fc⊥x' = 344.50 psi  (CSI = 0.29)   ➜  OK
8/15/2021 6
