Size: 5.5 x 7.5
Design Span (L): 11.65 ft.
Clear Span: 11.19 ft.
Total Span: 12.10 ft.
Bearing (lb): 5.5 in.
Dead Load: 220 plf
Selfweight: 112.6 lbs
Dist. Selfweight: 9.67 plf
Total Weight: 117.1 lbs
Beam Design 2021A465
8/12/2021 1
d = 7.500 in.
A = 5.500 x 7.500 = 41.25 in.2
Sx = (5.500)(7.500)2/6 = 51.56 in.3
Sy = (5.500)2(7.500)/6 = 37.81 in.3
Ix = (5.500)(7.500)3/12 = 193.36 in.4
Iy = (5.500)3(7.500)/12 = 103.98 in.4
8/12/2021 2
Volumetotal = N[A x (L + lb)] = 1 x [41.25 x (139.74 + 5.5)] x (12 in./ft.)3 = 3.47 ft3
Volumespan = N[A x L] = 1 x [41.25 x 139.74] x (12 in./ft.)3 = 3.34 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 3.47 = 117.1 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 3.34 = 112.6 lbs
Distributed Self Weight (ws) = = 9.67 plf
220 plf
  ws = 9.67 plf
11.65 ft.
11.19 ft.
12.10 ft.
1995.06 lbs
1995.06 lbs
8/12/2021 3
Fbx' = (2400)(1.15)(1)(0.8)(1.0) = 2208.0 psi
fb = = 1300.5 psi
 fb = 1300.5 psi < Fbx' = 2208.0 psi  (CSI = 0.59)   ➜  OK
8/12/2021 4
Fvx' = (265)(1.15)(1)(0.8) = 243.80 psi
fv* = = 62.31 psi
 fv* = 62.31 psi < Fvx' = 243.80 psi  (CSI = 0.26)   ➜  OK
fv = = 69.80 psi
 fv = 69.80 psi < Fvx' = 243.80 psi  (CSI = 0.29)   ➜  OK
8/12/2021 5
ΔLL = = 0.13 in.
(L/d)LL = 139.74 / 0.13 = 1058
 ΔLL = 0.13 in = L/1058 < L/360   ➜  OK
ΔTL = = 0.44 in.
(L/d)TL = 139.74 / 0.44 = 321
 ΔTL = 0.44 in = L/321 < L/240   ➜  OK
fc⊥ = = 66.0 psi
 fc⊥ = 66.0 psi < Fc⊥x' = 520.00 psi  (CSI = 0.13)   ➜  OK
8/12/2021 6
