Beam Design - Ortega Addition
Size: 4 x 8
Design Span (L): 6.25 ft.
Clear Span: 6.00 ft.
Total Span: 6.50 ft.
Live Load: 400 plf
Dead Load: 140 plf
Selfweight: 37.7 lbs
Dist. Selfweight: 6.03 plf
Total Weight: 39.2 lbs
Beam Design Luis Ortega 3917 Woodpointe Circle 21-09
8/11/2021 1
8/11/2021 2
Volumetotal = N[A x (L + lb)] = 1 x [25.38 x (75.00 + 3)] x (12 in./ft.)3 = 1.15 ft3
Volumespan = N[A x L] = 1 x [25.38 x 75.00] x (12 in./ft.)3 = 1.10 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 1.15 = 39.2 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 1.10 = 37.7 lbs
400 plf
140 plf
ws = 6.03 plf
6.25 ft.
6.50 ft.
1774.59 lbs
1774.59 lbs
8/11/2021 3
fb = = 1043.5 psi
 fb = 1043.5 psi < Fbx' = 1170.0 psi  (CSI = 0.89)   ➜  OK
8/11/2021 4
fv* = = 81.37 psi
 fv* = 81.37 psi < Fvx' = 180.00 psi  (CSI = 0.45)   ➜  OK
fv = = 100.87 psi
 fv = 100.87 psi < Fvx' = 180.00 psi  (CSI = 0.56)   ➜  OK
8/11/2021 5
ΔLL = = 0.08 in.
(L/d)LL = 75.00 / 0.08 = 971
 ΔLL = 0.08 in = L/971 < L/360   ➜  OK
ΔTL = = 0.11 in.
(L/d)TL = 75.00 / 0.11 = 711
 ΔTL = 0.11 in = L/711 < L/240   ➜  OK
fc⊥ = = 169.0 psi
 fc⊥ = 169.0 psi < Fc⊥x' = 625.00 psi  (CSI = 0.27)   ➜  OK
8/11/2021 6
