Beam Design - Ortega Addition
Design Span (L): 10.25 ft.
Clear Span: 10.00 ft.
Total Span: 10.50 ft.
Live Load: 54 plf
Dead Load: 18 plf
Selfweight: 26.5 lbs
Dist. Selfweight: 2.58 plf
Total Weight: 27.1 lbs
Beam Design Luis Ortega 3917 Woodpointe Circle 21-09
8/11/2021 1
8/11/2021 2
Volumetotal = N[A x (L + lb)] = 1 x [10.88 x (123.00 + 3)] x (12 in./ft.)3 = 0.79 ft3
Volumespan = N[A x L] = 1 x [10.88 x 123.00] x (12 in./ft.)3 = 0.77 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 0.79 = 27.1 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 0.77 = 26.5 lbs
54 plf
18 plf
ws = 2.58 plf
10.25 ft.
10.00 ft.
10.50 ft.
391.56 lbs
391.56 lbs
8/11/2021 3
Fbx' = (900)(1.00)(1)(1)(1)(1.2)(1)(1.15) = 1242.0 psi
fb = = 894.5 psi
 fb = 894.5 psi < Fbx' = 1242.0 psi  (CSI = 0.72)   ➜  OK
8/11/2021 4
fv* = = 46.51 psi
 fv* = 46.51 psi < Fvx' = 180.00 psi  (CSI = 0.26)   ➜  OK
fv = = 52.72 psi
 fv = 52.72 psi < Fvx' = 180.00 psi  (CSI = 0.29)   ➜  OK
8/11/2021 5
ΔLL = = 0.18 in.
(L/d)LL = 123.00 / 0.18 = 699
 ΔLL = 0.18 in = L/699 < L/360   ➜  OK
ΔTL = = 0.24 in.
(L/d)TL = 123.00 / 0.24 = 506
 ΔTL = 0.24 in = L/506 < L/240   ➜  OK
fc⊥ = = 87.0 psi
 fc⊥ = 87.0 psi < Fc⊥x' = 625.00 psi  (CSI = 0.14)   ➜  OK
8/11/2021 6
