Size: 5.125 x 18
Design Span (L): 19.50 ft.
Clear Span: 19.00 ft.
Total Span: 20.00 ft.
Selfweight: 421.8 lbs
Dist. Selfweight: 21.63 plf
Total Weight: 432.6 lbs
CV Volume Factor 0.967b - - - - -
Beam Design 2021A459
8/10/2021 1
b = 5.125 in.
d = 18.000 in.
A = 5.125 x 18.000 = 92.25 in.2
Sx = (5.125)(18.000)2/6 = 276.75 in.3
Sy = (5.125)2(18.000)/6 = 78.80 in.3
Ix = (5.125)(18.000)3/12 = 2490.75 in.4
Iy = (5.125)3(18.000)/12 = 201.92 in.4
8/10/2021 2
Volumetotal = N[A x (L + lb)] = 1 x [92.25 x (234.00 + 6)] x (12 in./ft.)3 = 12.81 ft3
Volumespan = N[A x L] = 1 x [92.25 x 234.00] x (12 in./ft.)3 = 12.49 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 12.81 = 432.6 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 12.49 = 421.8 lbs
Distributed Self Weight (ws) = = 21.63 plf
  ws = 21.63 plf
19.50 ft.
19.00 ft.
1966.28 lbs
1966.28 lbs
8/10/2021 3
CV = = 0.967
CV = 0.967 < CL = 1
Fbx' = (2400)(1.00)(1)(1)(0.967) = 2321.8 psi
fb = = 405.2 psi
 fb = 405.2 psi < Fbx' = 2321.8 psi  (CSI = 0.17)   ➜  OK
8/10/2021 4
fv* = = 26.38 psi
 fv* = 26.38 psi < Fvx' = 265.00 psi  (CSI = 0.10)   ➜  OK
fv = = 31.17 psi
 fv = 31.17 psi < Fvx' = 265.00 psi  (CSI = 0.12)   ➜  OK
8/10/2021 5
ΔLL = = 0.07 in.
(L/d)LL = 234.00 / 0.07 = 3225
 ΔLL = 0.07 in = L/3225 < L/180   ➜  OK
ΔTL = = 0.14 in.
(L/d)TL = 234.00 / 0.14 = 1640
 ΔTL = 0.14 in = L/1640 < L/120   ➜  OK
Ab = b x lb = 5.125 x 6 = 30.75 in2
fc⊥ = = 63.9 psi
 fc⊥ = 63.9 psi < Fc⊥x' = 650.00 psi  (CSI = 0.10)   ➜  OK
8/10/2021 6
