Grade: SPF No.2
Design Span (L): 9.75 ft.
Clear Span: 9.50 ft.
Total Span: 10.00 ft.
Quantity (N): 5
Live Load: 480 plf
Dead Load: 180 plf
Selfweight: 81.3 lbs
Dist. Selfweight: 8.34 plf
Total Weight: 83.4 lbs
Beam Design 2021A456
8/3/2021 1
8/3/2021 2
Volumetotal = N[A x (L + lb)] = 5 x [8.25 x (117.00 + 3)] x (12 in./ft.)3 = 2.86 ft3
Volumespan = N[A x L] = 5 x [8.25 x 117.00] x (12 in./ft.)3 = 2.79 ft3
Total Weight (WT) = ρw x Volumetotal = 29.10 x 2.86 = 83.4 lbs
Self Weight (WS) = ρw x Volumespan = 29.10 x 2.79 = 81.3 lbs
Distributed Self Weight (ws) = = 8.34 plf
480 plf
180 plf
ws = 8.34 plf
9.75 ft.
9.50 ft.
10.00 ft.
3341.68 lbs
3341.68 lbs
8/3/2021 3
Fbx' = (875)(1.15)(1)(1)(1)(1.3)(1)(1) = 1308.1 psi
fb = = 2520.3 psi
 fb = 2520.3 psi > Fbx' = 1308.1 psi  (CSI = 1.93)   ➜  NG
8/3/2021 4
fv* = = 107.34 psi
 fv* = 107.34 psi < Fvx' = 155.25 psi  (CSI = 0.69)   ➜  OK
fv = = 118.48 psi
 fv = 118.48 psi < Fvx' = 155.25 psi  (CSI = 0.76)   ➜  OK
8/3/2021 5
ΔLL = = 0.67 in.
(L/d)LL = 117.00 / 0.67 = 175
 ΔLL = 0.67 in = L/175 > L/360   ➜  NG
ΔTL = = 0.93 in.
(L/d)TL = 117.00 / 0.93 = 125
 ΔTL = 0.93 in = L/125 > L/240   ➜  NG
fc⊥ = = 148.5 psi
 fc⊥ = 148.5 psi < Fc⊥x' = 425.00 psi  (CSI = 0.35)   ➜  OK
8/3/2021 6
