Grade: SPF No.2
Live Load: 53 plf
Dead Load: 20 plf
Selfweight: 25.8 lbs
Dist. Selfweight: 2.20 plf
Total Weight: 26.4 lbs
Beam Design 2021A455
8/3/2021 1
8/3/2021 2
Volumetotal = N[A x (L + lb)] = 1 x [10.88 x (141.00 + 3)] x (12 in./ft.)3 = 0.91 ft3
Volumespan = N[A x L] = 1 x [10.88 x 141.00] x (12 in./ft.)3 = 0.89 ft3
Total Weight (WT) = ρw x Volumetotal = 29.10 x 0.91 = 26.4 lbs
Self Weight (WS) = ρw x Volumespan = 29.10 x 0.89 = 25.8 lbs
Distributed Self Weight (ws) = = 2.20 plf
53 plf
20 plf
ws = 2.20 plf
451.18 lbs
451.18 lbs
8/3/2021 3
Fbx' = (875)(1.15)(1)(1)(1)(1.2)(1)(1) = 1207.5 psi
fb = = 1185.1 psi
 fb = 1185.1 psi < Fbx' = 1207.5 psi  (CSI = 0.98)   ➜  OK
8/3/2021 4
fv* = = 54.67 psi
 fv* = 54.67 psi < Fvx' = 155.25 psi  (CSI = 0.35)   ➜  OK
fv = = 60.94 psi
 fv = 60.94 psi < Fvx' = 155.25 psi  (CSI = 0.39)   ➜  OK
8/3/2021 5
ΔLL = = 0.34 in.
(L/d)LL = 141.00 / 0.34 = 414
 ΔLL = 0.34 in = L/414 < L/360   ➜  OK
ΔTL = = 0.48 in.
(L/d)TL = 141.00 / 0.48 = 292
fc⊥ = = 100.3 psi
 fc⊥ = 100.3 psi < Fc⊥x' = 425.00 psi  (CSI = 0.24)   ➜  OK
8/3/2021 6
