Design Span (L): 13.50 ft.
Clear Span: 13.00 ft.
Total Span: 14.00 ft.
Dead Load: 15 plf
Selfweight: 54.1 lbs
Dist. Selfweight: 4.01 plf
Total Weight: 56.1 lbs
Notes: Rafter
LL 100 PSF
DL 15 PSF
Beam Design GWE L9
1/15/2021 1
Beam Design GWE L9
1/15/2021 2
Volumetotal = N[A x (L + lb)] = 1 x [16.88 x (162.00 + 6)] x (12 in./ft.)3 = 1.64 ft3
Volumespan = N[A x L] = 1 x [16.88 x 162.00] x (12 in./ft.)3 = 1.58 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 1.64 = 56.1 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 1.58 = 54.1 lbs
15 plf
ws = 4.01 plf
13.50 ft.
13.00 ft.
833.06 lbs
833.06 lbs
Beam Design GWE L9
1/15/2021 3
fb = = 1028.2 psi
 fb = 1028.2 psi < Fbx' = 1035.0 psi  (CSI = 0.99)   ➜  OK
Beam Design GWE L9
1/15/2021 4
fv* = = 61.49 psi
 fv* = 61.49 psi < Fvx' = 207.00 psi  (CSI = 0.30)   ➜  OK
fv = = 71.40 psi
 fv = 71.40 psi < Fvx' = 207.00 psi  (CSI = 0.34)   ➜  OK
Beam Design GWE L9
1/15/2021 5
ΔLL = = 0.26 in.
(L/d)LL = 162.00 / 0.26 = 617
 ΔLL = 0.26 in = L/617 < L/360   ➜  OK
ΔTL = = 0.31 in.
(L/d)TL = 162.00 / 0.31 = 519
 ΔTL = 0.31 in = L/519 < L/240   ➜  OK
fc⊥ = = 92.6 psi
 fc⊥ = 92.6 psi < Fc⊥x' = 625.00 psi  (CSI = 0.15)   ➜  OK
Beam Design GWE L9
1/15/2021 6
