Dead Load: 41 plf
Selfweight: 60.7 lbs
Dist. Selfweight: 5.17 plf
Total Weight: 62.0 lbs
Beam Design 2021A448
8/2/2021 1
8/2/2021 2
Volumetotal = N[A x (L + lb)] = 2 x [10.88 x (141.00 + 3)] x (12 in./ft.)3 = 1.81 ft3
Volumespan = N[A x L] = 2 x [10.88 x 141.00] x (12 in./ft.)3 = 1.77 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 1.81 = 62.0 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 1.77 = 60.7 lbs
41 plf
ws = 5.17 plf
877.00 lbs
877.00 lbs
8/2/2021 3
Fbx' = (900)(1.00)(1)(1)(1)(1.2)(1)(1) = 1080.0 psi
fb = = 1151.8 psi
 fb = 1151.8 psi > Fbx' = 1080.0 psi  (CSI = 1.07)   ➜  NG
8/2/2021 4
fv* = = 53.13 psi
 fv* = 53.13 psi < Fvx' = 180.00 psi  (CSI = 0.30)   ➜  OK
fv = = 59.22 psi
 fv = 59.22 psi < Fvx' = 180.00 psi  (CSI = 0.33)   ➜  OK
8/2/2021 5
ΔLL = = 0.28 in.
(L/d)LL = 141.00 / 0.28 = 501
 ΔLL = 0.28 in = L/501 < L/180   ➜  OK
ΔTL = = 0.41 in.
(L/d)TL = 141.00 / 0.41 = 343
 ΔTL = 0.41 in = L/343 < L/120   ➜  OK
fc⊥ = = 97.4 psi
 fc⊥ = 97.4 psi < Fc⊥x' = 625.00 psi  (CSI = 0.16)   ➜  OK
8/2/2021 6
