Beam Design - PORCH WOOD HEADER BEAM
Design Span (L): 9.75 ft.
Clear Span: 9.50 ft.
Total Span: 10.00 ft.
Selfweight: 32.1 lbs
Dist. Selfweight: 3.30 plf
Total Weight: 33.0 lbs
Beam Design JUAN DURAN 1306 10th ave 1306-21
7/30/2021 1
7/30/2021 2
Volumetotal = N[A x (L + lb)] = 1 x [13.88 x (117.00 + 3)] x (12 in./ft.)3 = 0.96 ft3
Volumespan = N[A x L] = 1 x [13.88 x 117.00] x (12 in./ft.)3 = 0.94 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 0.96 = 33.0 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 0.94 = 32.1 lbs
ws = 3.30 plf
9.75 ft.
9.50 ft.
10.00 ft.
891.48 lbs
891.48 lbs
7/30/2021 3
fb = = 1188.6 psi
 fb = 1188.6 psi > Fbx' = 1138.5 psi  (CSI = 1.04)   ➜  NG
7/30/2021 4
fv* = = 79.11 psi
 fv* = 79.11 psi < Fvx' = 207.00 psi  (CSI = 0.38)   ➜  OK
fv = = 93.97 psi
 fv = 93.97 psi < Fvx' = 207.00 psi  (CSI = 0.45)   ➜  OK
7/30/2021 5
ΔLL = = 0.13 in.
(L/d)LL = 117.00 / 0.13 = 911
 ΔLL = 0.13 in = L/911 < L/360   ➜  OK
ΔTL = = 0.23 in.
(L/d)TL = 117.00 / 0.23 = 511
 ΔTL = 0.23 in = L/511 < L/240   ➜  OK
fc⊥ = = 198.1 psi
 fc⊥ = 198.1 psi < Fc⊥x' = 625.00 psi  (CSI = 0.32)   ➜  OK
7/30/2021 6
