Beam Design - Ceiling Joist
Design Span (L): 12.25 ft.
Clear Span: 12.00 ft.
Total Span: 12.50 ft.
Live Load: 720 lbs
Dead Load: 270 lbs
Selfweight: 80.7 lbs
Dist. Selfweight: 6.59 plf
Total Weight: 82.4 lbs
Notes: Analysis of (2) 2x10 ceiling joist w/ point load only
CL Beam Stability Factor 0.987 - - - - -
Beam Design 171 Maple St 2021A440
7/29/2021 1
7/29/2021 2
Volumetotal = N[A x (L + lb)] = 2 x [13.88 x (147.00 + 3)] x (12 in./ft.)3 = 2.41 ft3
Volumespan = N[A x L] = 2 x [13.88 x 147.00] x (12 in./ft.)3 = 2.36 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 2.41 = 82.4 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 2.36 = 80.7 lbs
720 lbs
270 lbs
ws = 6.59 plf
12.25 ft.
12.50 ft.
536.20 lbs
536.20 lbs
7/29/2021 3
lu = Unbraced Length = 6 ft.
lu/d = = 7.78
le = 1.63lu + 3d = 1.63(72.0) + 3(9.25) = 145.11 in. = 12.09 ft.  (NDS Table 3.3.3)
Rb = = 12.21
 Rb = 12.21 < 50   ➜  OK
7/29/2021 4
FbE = = 4666.73 psi
Fbx* = Fbx(CD)(CM)(Ct)(CF)(Ci)(Cr) = (900)(1.00)(1)(1)(1.1)(1)(1) = 990.00 psi
CL =   = 0.987
Fbx' = (900)(1.00)(1)(1)(0.987)(1.1)(1)(1) = 977.1 psi
fb = = 885.1 psi
 fb = 885.1 psi < Fbx' = 977.1 psi  (CSI = 0.91)   ➜  OK
fv* = = 28.66 psi
 fv* = 28.66 psi < Fvx' = 180.00 psi  (CSI = 0.16)   ➜  OK
fv = = 28.94 psi
 fv = 28.94 psi < Fvx' = 180.00 psi  (CSI = 0.16)   ➜  OK
7/29/2021 5
ΔLL =   =   = 0.15 in.
(L/d)LL = 147.00 / 0.15 = 977
 ΔLL = 0.15 in = L/977 < L/360   ➜  OK
ΔTL =   =   = 0.22 in.
(L/d)TL = 147.00 / 0.22 = 676
 ΔTL = 0.22 in = L/676 < L/240   ➜  OK
fc⊥ = = 59.6 psi
 fc⊥ = 59.6 psi < Fc⊥x' = 625.00 psi  (CSI = 0.10)   ➜  OK
7/29/2021 6
