Size: 5.5 x 15
Design Span (L): 17.54 ft.
Clear Span: 17.08 ft.
Total Span: 18.00 ft.
Bearing (lb): 5.5 in.
Live Load: 260 plf
Dead Load: 195 plf
Selfweight: 339.3 lbs
Dist. Selfweight: 19.34 plf
Total Weight: 348.2 lbs
Load Duration: 1.25
CL Beam Stability Factor 0.946 - - - - -
CV Volume Factor 0.989b - - - - -
Beam Design 2021A436
7/27/2021 1
d = 15.000 in.
A = 5.500 x 15.000 = 82.50 in.2
Sx = (5.500)(15.000)2/6 = 206.25 in.3
Sy = (5.500)2(15.000)/6 = 75.63 in.3
Ix = (5.500)(15.000)3/12 = 1546.88 in.4
Iy = (5.500)3(15.000)/12 = 207.97 in.4
7/27/2021 2
Volumetotal = N[A x (L + lb)] = 1 x [82.50 x (210.50 + 5.5)] x (12 in./ft.)3 = 10.31 ft3
Volumespan = N[A x L] = 1 x [82.50 x 210.50] x (12 in./ft.)3 = 10.05 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 10.31 = 348.2 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 10.05 = 339.3 lbs
Distributed Self Weight (ws) = = 19.34 plf
260 plf
195 plf
  ws = 19.34 plf
17.54 ft.
17.08 ft.
18.00 ft.
4269.16 lbs
4269.16 lbs
7/27/2021 3
lu = Unbraced Length = 17.542 ft.
lu/d = = 14.03
le = 1.63lu + 3d = 1.63(210.5) + 3(15) = 388.12 in. = 32.34 ft.  (NDS Table 3.3.3)
Rb = = 13.87
 Rb = 13.87 < 50   ➜  OK
7/27/2021 4
FbE = = 5299.89 psi
Fbx* = Fbx(CD)(CM)(Ct) = (2400)(1.25)(1)(1) = 3000.00 psi
CL =   = 0.946
CV = = 0.989
CL = 0.946 < CV = 0.989
Fbx' = (2400)(1.25)(1)(1)(0.946) = 2836.7 psi
fb = = 1061.6 psi
 fb = 1061.6 psi < Fbx' = 2836.7 psi  (CSI = 0.37)   ➜  OK
fv* = = 64.86 psi
7/27/2021 5
 fv* = 64.86 psi < Fvx' = 331.25 psi  (CSI = 0.20)   ➜  OK
fv = = 75.64 psi
 fv = 75.64 psi < Fvx' = 331.25 psi  (CSI = 0.23)   ➜  OK
ΔLL = = 0.20 in.
(L/d)LL = 210.50 / 0.20 = 1058
 ΔLL = 0.20 in = L/1058 < L/240   ➜  OK
ΔTL = = 0.36 in.
(L/d)TL = 210.50 / 0.36 = 580
 ΔTL = 0.36 in = L/580 < L/180   ➜  OK
7/27/2021 6
fc⊥ = = 141.1 psi
 fc⊥ = 141.1 psi < Fc⊥x' = 650.00 psi  (CSI = 0.22)   ➜  OK
7/27/2021 7
