Size: 3.5 x 7.5
Design Span (L): 13.58 ft.
Clear Span: 13.33 ft.
Total Span: 13.83 ft.
Quantity (N): 7
Live Load: 74.00 plf
Dead Load: 10 plf
Selfweight: 585.2 lbs
Dist. Selfweight: 43.08 plf
Total Weight: 595.9 lbs
Beam Design 2021A435
7/26/2021 1
d = 7.500 in.
A = 3.500 x 7.500 = 26.25 in.2
Sx = (3.500)(7.500)2/6 = 32.81 in.3
Sy = (3.500)2(7.500)/6 = 15.31 in.3
Ix = (3.500)(7.500)3/12 = 123.05 in.4
Iy = (3.500)3(7.500)/12 = 26.80 in.4
7/26/2021 2
Volumetotal = N[A x (L + lb)] = 7 x [26.25 x (163.00 + 3)] x (12 in./ft.)3 = 17.65 ft3
Volumespan = N[A x L] = 7 x [26.25 x 163.00] x (12 in./ft.)3 = 17.33 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 17.65 = 595.9 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 17.33 = 585.2 lbs
Distributed Self Weight (ws) = = 43.08 plf
74.00 plf
10 plf
  ws = 43.08 plf
13.58 ft.
13.33 ft.
13.83 ft.
878.95 lbs
878.95 lbs
7/26/2021 3
fb = = 153.1 psi
 fb = 153.1 psi < Fbx' = 2760.0 psi  (CSI = 0.06)   ➜  OK
7/26/2021 4
fv* = = 6.40 psi
 fv* = 6.40 psi < Fvx' = 304.75 psi  (CSI = 0.02)   ➜  OK
fv = = 7.05 psi
 fv = 7.05 psi < Fvx' = 304.75 psi  (CSI = 0.02)   ➜  OK
7/26/2021 5
ΔLL = = 0.04 in.
(L/d)LL = 163.00 / 0.04 = 4459
 ΔLL = 0.04 in = L/4459 < L/360   ➜  OK
ΔTL = = 0.06 in.
(L/d)TL = 163.00 / 0.06 = 2596
 ΔTL = 0.06 in = L/2596 < L/240   ➜  OK
fc⊥ = = 12.0 psi
 fc⊥ = 12.0 psi < Fc⊥x' = 650.00 psi  (CSI = 0.02)   ➜  OK
7/26/2021 6
