Beam Design - sdfsd
Grade: DF SS
Design Span (L): 9.75 ft.
Clear Span: 9.50 ft.
Total Span: 10.00 ft.
Live Load: 27 plf
Dead Load: 27 plf
Selfweight: 32.1 lbs
Dist. Selfweight: 3.30 plf
Total Weight: 33.0 lbs
Notes: sd
Beam Design sdsd sdsds sdsds 0114
7/26/2021 1
7/26/2021 2
Volumetotal = N[A x (L + lb)] = 1 x [13.88 x (117.00 + 3)] x (12 in./ft.)3 = 0.96 ft3
Volumespan = N[A x L] = 1 x [13.88 x 117.00] x (12 in./ft.)3 = 0.94 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 0.96 = 33.0 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 0.94 = 32.1 lbs
27 plf
27 plf
ws = 3.30 plf
9.75 ft.
9.50 ft.
10.00 ft.
286.48 lbs
286.48 lbs
7/26/2021 3
Fbx' = (1500)(1.00)(1)(1)(1)(1.1)(1)(1) = 1650.0 psi
fb = = 381.9 psi
 fb = 381.9 psi < Fbx' = 1650.0 psi  (CSI = 0.23)   ➜  OK
7/26/2021 4
fv* = = 25.42 psi
 fv* = 25.42 psi < Fvx' = 180.00 psi  (CSI = 0.14)   ➜  OK
fv = = 30.20 psi
 fv = 30.20 psi < Fvx' = 180.00 psi  (CSI = 0.17)   ➜  OK
7/26/2021 5
ΔLL = = 0.03 in.
(L/d)LL = 117.00 / 0.03 = 4006
 ΔLL = 0.03 in = L/4006 < L/240   ➜  OK
ΔTL = = 0.06 in.
(L/d)TL = 117.00 / 0.06 = 1888
 ΔTL = 0.06 in = L/1888 < L/180   ➜  OK
fc⊥ = = 63.7 psi
 fc⊥ = 63.7 psi < Fc⊥x' = 625.00 psi  (CSI = 0.10)   ➜  OK
7/26/2021 6
