Beam Design - sdfsd
Grade: DF SS
Design Span (L): 16.25 ft.
Clear Span: 16.00 ft.
Total Span: 16.50 ft.
Live Load: 27 plf
Dead Load: 27 plf
Selfweight: 65.1 lbs
Dist. Selfweight: 4.01 plf
Total Weight: 66.1 lbs
Notes: sd
Beam Design sdsd sdsds sdsds 0114
7/26/2021 1
7/26/2021 2
Volumetotal = N[A x (L + lb)] = 1 x [16.88 x (195.00 + 3)] x (12 in./ft.)3 = 1.93 ft3
Volumespan = N[A x L] = 1 x [16.88 x 195.00] x (12 in./ft.)3 = 1.90 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 1.93 = 66.1 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 1.90 = 65.1 lbs
27 plf
27 plf
ws = 4.01 plf
16.25 ft.
16.50 ft.
478.57 lbs
478.57 lbs
7/26/2021 3
Fbx' = (1500)(1.00)(1)(1)(1)(1)(1)(1) = 1500.0 psi
fb = = 726.2 psi
 fb = 726.2 psi < Fbx' = 1500.0 psi  (CSI = 0.48)   ➜  OK
7/26/2021 4
fv* = = 37.06 psi
 fv* = 37.06 psi < Fvx' = 180.00 psi  (CSI = 0.21)   ➜  OK
fv = = 41.89 psi
 fv = 41.89 psi < Fvx' = 180.00 psi  (CSI = 0.23)   ➜  OK
7/26/2021 5
ΔLL = = 0.13 in.
(L/d)LL = 195.00 / 0.13 = 1557
 ΔLL = 0.13 in = L/1557 < L/240   ➜  OK
ΔTL = = 0.27 in.
(L/d)TL = 195.00 / 0.27 = 725
 ΔTL = 0.27 in = L/725 < L/180   ➜  OK
fc⊥ = = 106.3 psi
 fc⊥ = 106.3 psi < Fc⊥x' = 625.00 psi  (CSI = 0.17)   ➜  OK
7/26/2021 6
