Beam Design - sdfsd
Grade: DF SS
Design Span (L): 21.25 ft.
Clear Span: 21.00 ft.
Total Span: 21.50 ft.
Live Load: 40 plf
Dead Load: 15 plf
Selfweight: 85.2 lbs
Dist. Selfweight: 4.01 plf
Total Weight: 86.2 lbs
Notes: sd
Beam Design sdsd sdsds sdsds 0114
7/26/2021 1
7/26/2021 2
Volumetotal = N[A x (L + lb)] = 1 x [16.88 x (255.00 + 3)] x (12 in./ft.)3 = 2.52 ft3
Volumespan = N[A x L] = 1 x [16.88 x 255.00] x (12 in./ft.)3 = 2.49 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 2.52 = 86.2 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 2.49 = 85.2 lbs
40 plf
15 plf
ws = 4.01 plf
21.25 ft.
21.00 ft.
21.50 ft.
634.34 lbs
634.34 lbs
7/26/2021 3
Fbx' = (1500)(1.00)(1)(1)(1)(1)(1)(1) = 1500.0 psi
fb = = 1263.2 psi
 fb = 1263.2 psi < Fbx' = 1500.0 psi  (CSI = 0.84)   ➜  OK
7/26/2021 4
fv* = = 50.81 psi
 fv* = 50.81 psi < Fvx' = 180.00 psi  (CSI = 0.28)   ➜  OK
fv = = 55.73 psi
 fv = 55.73 psi < Fvx' = 180.00 psi  (CSI = 0.31)   ➜  OK
7/26/2021 5
ΔLL = = 0.54 in.
(L/d)LL = 255.00 / 0.54 = 470
 ΔLL = 0.54 in = L/470 < L/360   ➜  OK
ΔTL = = 0.80 in.
(L/d)TL = 255.00 / 0.80 = 319
 ΔTL = 0.80 in = L/319 < L/240   ➜  OK
fc⊥ = = 141.0 psi
 fc⊥ = 141.0 psi < Fc⊥x' = 625.00 psi  (CSI = 0.23)   ➜  OK
7/26/2021 6
