Size: 5.5 x 13.5
Design Span (L): 16.25 ft.
Clear Span: 16.00 ft.
Total Span: 16.50 ft.
Selfweight: 282.9 lbs
Dist. Selfweight: 17.41 plf
Total Weight: 287.2 lbs
Beam Design 2021A423
7/23/2021 1
d = 13.500 in.
7/23/2021 2
Volumetotal = N[A x (L + lb)] = 1 x [74.25 x (195.00 + 3)] x (12 in./ft.)3 = 8.51 ft3
Volumespan = N[A x L] = 1 x [74.25 x 195.00] x (12 in./ft.)3 = 8.38 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 8.51 = 287.2 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 8.38 = 282.9 lbs
  ws = 17.41 plf
16.25 ft.
16.50 ft.
1587.37 lbs
1587.37 lbs
7/23/2021 3
Fbx' = (2400)(1.15)(1)(0.8)(1.0) = 2208.0 psi
fb = = 456.2 psi
 fb = 456.2 psi < Fbx' = 2208.0 psi  (CSI = 0.21)   ➜  OK
7/23/2021 4
Fvx' = (265)(1.15)(1)(0.8) = 243.80 psi
fv* = = 27.21 psi
 fv* = 27.21 psi < Fvx' = 243.80 psi  (CSI = 0.11)   ➜  OK
fv = = 31.58 psi
 fv = 31.58 psi < Fvx' = 243.80 psi  (CSI = 0.13)   ➜  OK
7/23/2021 5
ΔLL = = 0.09 in.
(L/d)LL = 195.00 / 0.09 = 2271
 ΔLL = 0.09 in = L/2271 < L/180   ➜  OK
ΔTL = = 0.17 in.
(L/d)TL = 195.00 / 0.17 = 1180
 ΔTL = 0.17 in = L/1180 < L/120   ➜  OK
fc⊥ = = 96.2 psi
 fc⊥ = 96.2 psi < Fc⊥x' = 520.00 psi  (CSI = 0.19)   ➜  OK
7/23/2021 6
