Design Span (L): 11.67 ft.
Clear Span: 11.33 ft.
Bearing (lb): 4 in.
Selfweight: 30.1 lbs
Dist. Selfweight: 2.58 plf
Total Weight: 31.0 lbs
Beam Design 2021A420
7/20/2021 1
7/20/2021 2
Volumetotal = N[A x (L + lb)] = 1 x [10.88 x (140.00 + 4)] x (12 in./ft.)3 = 0.91 ft3
Volumespan = N[A x L] = 1 x [10.88 x 140.00] x (12 in./ft.)3 = 0.88 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 0.91 = 31.0 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 0.88 = 30.1 lbs
ws = 2.58 plf
11.67 ft.
11.33 ft.
1065.53 lbs
1065.53 lbs
7/20/2021 3
fb = = 2759.3 psi
 fb = 2759.3 psi > Fbx' = 1242.0 psi  (CSI = 2.22)   ➜  NG
7/20/2021 4
fv* = = 128.09 psi
 fv* = 128.09 psi < Fvx' = 207.00 psi  (CSI = 0.62)   ➜  OK
fv = = 142.89 psi
 fv = 142.89 psi < Fvx' = 207.00 psi  (CSI = 0.69)   ➜  OK
7/20/2021 5
ΔLL = = 0.55 in.
(L/d)LL = 140.00 / 0.55 = 256
 ΔLL = 0.55 in = L/256 > L/360   ➜  NG
ΔTL = = 0.97 in.
(L/d)TL = 140.00 / 0.97 = 144
 ΔTL = 0.97 in = L/144 > L/240   ➜  NG
fc⊥ = = 177.6 psi
 fc⊥ = 177.6 psi < Fc⊥x' = 625.00 psi  (CSI = 0.28)   ➜  OK
7/20/2021 6
