Design Span (L): 13.77 ft.
Clear Span: 13.54 ft.
Total Span: 14.00 ft.
Bearing (lb): 2.75 in.
Live Load: 40 plf
Dead Load: 20 plf
Selfweight: 71.1 lbs
Dist. Selfweight: 5.17 plf
Total Weight: 72.3 lbs
CL Beam Stability Factor 0.967 - - - - -
Beam Design 2021A419
7/20/2021 1
7/20/2021 2
Volumetotal = N[A x (L + lb)] = 2 x [10.88 x (165.25 + 2.75)] x (12 in./ft.)3 = 2.11 ft3
Volumespan = N[A x L] = 2 x [10.88 x 165.25] x (12 in./ft.)3 = 2.08 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 2.11 = 72.3 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 2.08 = 71.1 lbs
40 plf
20 plf
ws = 5.17 plf
13.77 ft.
13.54 ft.
456.17 lbs
456.17 lbs
7/20/2021 3
lu = Unbraced Length = 13.771 ft.
lu/d = = 22.79
le = 1.63lu + 3d = 1.63(165.3) + 3(7.25) = 291.11 in. = 24.26 ft.  (NDS Table 3.3.3)
Rb = = 15.31
 Rb = 15.31 < 50   ➜  OK
7/20/2021 4
FbE = = 2967.94 psi
Fbx* = Fbx(CD)(CM)(Ct)(CF)(Ci)(Cr) = (900)(1.15)(1)(1)(1.2)(1)(1) = 1242.00 psi
CL =   = 0.967
Fbx' = (900)(1.15)(1)(1)(0.967)(1.2)(1)(1) = 1201.2 psi
fb = = 705.3 psi
 fb = 705.3 psi < Fbx' = 1201.2 psi  (CSI = 0.59)   ➜  OK
fv* = = 28.23 psi
 fv* = 28.23 psi < Fvx' = 207.00 psi  (CSI = 0.14)   ➜  OK
fv = = 30.94 psi
 fv = 30.94 psi < Fvx' = 207.00 psi  (CSI = 0.15)   ➜  OK
7/20/2021 5
ΔLL = = 0.21 in.
(L/d)LL = 165.25 / 0.21 = 778
 ΔLL = 0.21 in = L/778 < L/360   ➜  OK
ΔTL = = 0.35 in.
(L/d)TL = 165.25 / 0.35 = 478
 ΔTL = 0.35 in = L/478 < L/240   ➜  OK
fc⊥ = = 55.3 psi
 fc⊥ = 55.3 psi < Fc⊥x' = 625.00 psi  (CSI = 0.09)   ➜  OK
7/20/2021 6
