Grade: SPF No.2
Design Span (L): 10.75 ft.
Clear Span: 10.50 ft.
Total Span: 11.00 ft.
Live Load: 0 plf
Dead Load: 10 plf
Selfweight: 73.3 lbs
Dist. Selfweight: 6.82 plf
Total Weight: 75.0 lbs
Beam Design 2021A417
7/20/2021 1
7/20/2021 2
Volumetotal = N[A x (L + lb)] = 2 x [16.88 x (129.00 + 3)] x (12 in./ft.)3 = 2.58 ft3
Volumespan = N[A x L] = 2 x [16.88 x 129.00] x (12 in./ft.)3 = 2.52 ft3
Total Weight (WT) = ρw x Volumetotal = 29.10 x 2.58 = 75.0 lbs
Self Weight (WS) = ρw x Volumespan = 29.10 x 2.52 = 73.3 lbs
0 plf
10 plf
ws = 6.82 plf
10.75 ft.
10.50 ft.
11.00 ft.
92.51 lbs
92.51 lbs
7/20/2021 3
Fbx' = (875)(0.9)(1)(1)(1)(1)(1)(1) = 787.5 psi
fb = = 46.1 psi
 fb = 46.1 psi < Fbx' = 787.5 psi  (CSI = 0.06)   ➜  OK
7/20/2021 4
Fvx' = (135)(0.9)(1)(1)(1) = 121.50 psi
fv* = = 3.32 psi
 fv* = 3.32 psi < Fvx' = 121.50 psi  (CSI = 0.03)   ➜  OK
fv = = 4.02 psi
 fv = 4.02 psi < Fvx' = 121.50 psi  (CSI = 0.03)   ➜  OK
7/20/2021 5
ΔLL = = 0.00 in.
(L/d)LL = 129.00 / 0.00 = ∞
ΔTL = = 0.01 in.
(L/d)TL = 129.00 / 0.01 = 12720
 ΔTL = 0.01 in = L/12720 < L/120   ➜  OK
fc⊥ = = 10.3 psi
 fc⊥ = 10.3 psi < Fc⊥x' = 425.00 psi  (CSI = 0.02)   ➜  OK
7/20/2021 6
