Design Span (L): 13.77 ft.
Clear Span: 13.54 ft.
Total Span: 14.00 ft.
Bearing (lb): 2.75 in.
Live Load: 40 plf
Dead Load: 30 plf
Selfweight: 81.0 lbs
Dist. Selfweight: 5.88 plf
Total Weight: 82.3 lbs
Beam Design 2021A413
7/19/2021 1
7/19/2021 2
Volumetotal = N[A x (L + lb)] = 3 x [8.25 x (165.25 + 2.75)] x (12 in./ft.)3 = 2.41 ft3
Volumespan = N[A x L] = 3 x [8.25 x 165.25] x (12 in./ft.)3 = 2.37 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 2.41 = 82.3 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 2.37 = 81.0 lbs
Distributed Self Weight (ws) = = 5.88 plf
40 plf
30 plf
ws = 5.88 plf
13.77 ft.
13.54 ft.
531.16 lbs
531.16 lbs
7/19/2021 3
lu = Unbraced Length = 13.771 ft.
lu/d = = 30.05
le = 1.63lu + 3d = 1.63(165.3) + 3(5.5) = 285.86 in. = 23.82 ft.  (NDS Table 3.3.3)
Rb = = 8.81
 Rb = 8.81 < 50   ➜  OK
7/19/2021 4
Eminy' = Eminy(CM)(Ct)(Ci) = 580000(1)(0.9)(1) = 522000 psi
FbE = = 8067.88 psi
Fbx* = Fbx(CD)(CM)(Ct)(CF)(Ci)(Cr) = (900)(1.15)(1)(0.8)(1.3)(1)(1) = 1076.40 psi
CL =   = 0.992
Fbx' = (900)(1.15)(1)(0.8)(0.992)(1.3)(1)(1) = 1068.2 psi
fb = = 951.4 psi
 fb = 951.4 psi < Fbx' = 1068.2 psi  (CSI = 0.89)   ➜  OK
Fvx' = (180)(1.15)(1)(0.8)(1) = 165.60 psi
fv* = = 29.56 psi
 fv* = 29.56 psi < Fvx' = 165.60 psi  (CSI = 0.18)   ➜  OK
fv = = 31.66 psi
 fv = 31.66 psi < Fvx' = 165.60 psi  (CSI = 0.19)   ➜  OK
7/19/2021 5
Ex' = Ex(CM)(Ct)(Ci) = 1600000(1)(0.9)(1) = 1440000 psi
ΔLL = = 0.36 in.
(L/d)LL = 165.25 / 0.36 = 459
 ΔLL = 0.36 in = L/459 < L/240   ➜  OK
ΔTL = = 0.68 in.
(L/d)TL = 165.25 / 0.68 = 242
 ΔTL = 0.68 in = L/242 < L/180   ➜  OK
fc⊥ = = 42.9 psi
 fc⊥ = 42.9 psi < Fc⊥x' = 500.00 psi  (CSI = 0.09)   ➜  OK
7/19/2021 6
