Design Span (L): 12.77 ft.
Clear Span: 12.54 ft.
Total Span: 13.00 ft.
Bearing (lb): 2.75 in.
Selfweight: 99.0 lbs
Dist. Selfweight: 7.75 plf
Total Weight: 100.7 lbs
Load Duration: 1.33
CL Beam Stability Factor 0.989 - - - - -
Beam Design 2021A410
7/16/2021 1
7/16/2021 2
Volumetotal = N[A x (L + lb)] = 3 x [10.88 x (153.25 + 2.75)] x (12 in./ft.)3 = 2.95 ft3
Volumespan = N[A x L] = 3 x [10.88 x 153.25] x (12 in./ft.)3 = 2.89 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 2.95 = 100.7 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 2.89 = 99.0 lbs
Distributed Self Weight (ws) = = 7.75 plf
ws = 7.75 plf
12.77 ft.
12.54 ft.
13.00 ft.
1187.89 lbs
1187.89 lbs
7/16/2021 3
lu = Unbraced Length = 12.771 ft.
lu/d = = 21.14
le = 1.63lu + 3d = 1.63(153.3) + 3(7.25) = 271.55 in. = 22.63 ft.  (NDS Table 3.3.3)
Rb = = 9.86
 Rb = 9.86 < 50   ➜  OK
7/16/2021 4
Eminy' = Eminy(CM)(Ct)(Ci) = 580000(1)(0.9)(1) = 522000 psi
FbE = = 6442.99 psi
Fbx* = Fbx(CD)(CM)(Ct)(CF)(Ci)(Cr) = (900)(1.33)(1)(0.8)(1.2)(1)(1) = 1149.12 psi
CL =   = 0.989
Fbx' = (900)(1.33)(1)(0.8)(0.989)(1.2)(1)(1) = 1136.9 psi
fb = = 1134.1 psi
 fb = 1134.1 psi < Fbx' = 1136.9 psi  (CSI = 1.00)   ➜  OK
Fvx' = (180)(1.33)(1)(0.8)(1) = 191.52 psi
fv* = = 48.58 psi
 fv* = 48.58 psi < Fvx' = 191.52 psi  (CSI = 0.25)   ➜  OK
fv = = 53.65 psi
 fv = 53.65 psi < Fvx' = 191.52 psi  (CSI = 0.28)   ➜  OK
7/16/2021 5
Ex' = Ex(CM)(Ct)(Ci) = 1600000(1)(0.9)(1) = 1440000 psi
ΔLL = = 0.29 in.
(L/d)LL = 153.25 / 0.29 = 527
 ΔLL = 0.29 in = L/527 < L/360   ➜  OK
ΔTL = = 0.53 in.
(L/d)TL = 153.25 / 0.53 = 288
 ΔTL = 0.53 in = L/288 < L/240   ➜  OK
fc⊥ = = 96.0 psi
 fc⊥ = 96.0 psi < Fc⊥x' = 500.00 psi  (CSI = 0.19)   ➜  OK
7/16/2021 6
