Size: 6.75 x 18
Design Span (L): 18.00 ft.
Clear Span: 17.50 ft.
Total Span: 18.50 ft.
Live Load: 1500 plf
Dead Load: 100 plf
Selfweight: 512.7 lbs
Dist. Selfweight: 28.49 plf
Total Weight: 527.0 lbs
CV Volume Factor 0.949b - - - - -
Beam Design GWE L9
1/14/2021 1
b = 6.750 in.
d = 18.000 in.
A = 6.750 x 18.000 = 121.50 in.2
Sx = (6.750)(18.000)2/6 = 364.50 in.3
Sy = (6.750)2(18.000)/6 = 136.69 in.3
Ix = (6.750)(18.000)3/12 = 3280.50 in.4
Iy = (6.750)3(18.000)/12 = 461.32 in.4
Beam Design GWE L9
1/14/2021 2
Volumetotal = N[A x (L + lb)] = 1 x [121.50 x (216.00 + 6)] x (12 in./ft.)3 = 15.61 ft3
Volumespan = N[A x L] = 1 x [121.50 x 216.00] x (12 in./ft.)3 = 15.19 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 15.61 = 527.0 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 15.19 = 512.7 lbs
Distributed Self Weight (ws) = = 28.49 plf
1500 plf
  ws = 28.49 plf
18.00 ft.
17.50 ft.
18.50 ft.
15063.50 lbs
15063.50 lbs
Beam Design GWE L9
1/14/2021 3
CV = = 0.949
CV = 0.949 < CL = 1
Fbx' = (2400)(1.15)(1)(1)(0.949) = 2618.4 psi
fb = = 2171.3 psi
 fb = 2171.3 psi < Fbx' = 2618.4 psi  (CSI = 0.83)   ➜  OK
Beam Design GWE L9
1/14/2021 4
fv* = = 150.79 psi
 fv* = 150.79 psi < Fvx' = 304.75 psi  (CSI = 0.49)   ➜  OK
fv = = 180.94 psi
 fv = 180.94 psi < Fvx' = 304.75 psi  (CSI = 0.59)   ➜  OK
Beam Design GWE L9
1/14/2021 5
ΔLL = = 0.60 in.
(L/d)LL = 216.00 / 0.60 = 360
 ΔLL = 0.60 in = L/360 > L/360   ➜  NG
ΔTL = = 0.65 in.
(L/d)TL = 216.00 / 0.65 = 332
 ΔTL = 0.65 in = L/332 < L/240   ➜  OK
fc⊥ = = 371.9 psi
 fc⊥ = 371.9 psi < Fc⊥x' = 650.00 psi  (CSI = 0.57)   ➜  OK
Beam Design GWE L9
1/14/2021 6
