Design Span (L): 6.75 ft.
Clear Span: 6.50 ft.
Total Span: 7.00 ft.
Live Load: 130 plf
Dead Load: 10 plf
Selfweight: 28.1 lbs
Dist. Selfweight: 4.16 plf
Total Weight: 29.1 lbs
Beam Design 2021A409
7/16/2021 1
7/16/2021 2
Volumetotal = N[A x (L + lb)] = 1 x [16.88 x (81.00 + 3)] x (12 in./ft.)3 = 0.82 ft3
Volumespan = N[A x L] = 1 x [16.88 x 81.00] x (12 in./ft.)3 = 0.79 ft3
Total Weight (WT) = ρw x Volumetotal = 35.47 x 0.82 = 29.1 lbs
Self Weight (WS) = ρw x Volumespan = 35.47 x 0.79 = 28.1 lbs
Distributed Self Weight (ws) = = 4.16 plf
130 plf
10 plf
ws = 4.16 plf
6.75 ft.
6.50 ft.
7.00 ft.
504.55 lbs
504.55 lbs
7/16/2021 3
fb = = 311.4 psi
 fb = 311.4 psi < Fbx' = 1035.0 psi  (CSI = 0.30)   ➜  OK
7/16/2021 4
fv* = = 31.23 psi
 fv* = 31.23 psi < Fvx' = 200.79 psi  (CSI = 0.16)   ➜  OK
fv = = 43.25 psi
 fv = 43.25 psi < Fvx' = 200.79 psi  (CSI = 0.22)   ➜  OK
7/16/2021 5
ΔLL = = 0.02 in.
(L/d)LL = 81.00 / 0.02 = 3419
 ΔLL = 0.02 in = L/3419 < L/360   ➜  OK
ΔTL = = 0.03 in.
(L/d)TL = 81.00 / 0.03 = 3083
 ΔTL = 0.03 in = L/3083 < L/240   ➜  OK
fc⊥ = = 112.1 psi
 fc⊥ = 112.1 psi < Fc⊥x' = 418.75 psi  (CSI = 0.27)   ➜  OK
7/16/2021 6
