Species: Hem-Fir
Grade: HF SS
Design Span (L): 1.33 ft.
Clear Span: 1.21 ft.
Total Span: 1.46 ft.
Bearing (lb): 1.5 in.
Live Load: 540 plf
Dead Load: 170 plf
Selfweight: 4.6 lbs
Dist. Selfweight: 3.49 plf
Total Weight: 5.1 lbs
Orientation: Horizontal
Beam Design 2021A408
7/16/2021 1
G = 0.43
7/16/2021 2
= 29.74 lbs/ft3
Volumetotal = N[A x (L + lb)] = 1 x [16.88 x (16.00 + 1.5)] x (12 in./ft.)3 = 0.17 ft3
Volumespan = N[A x L] = 1 x [16.88 x 16.00] x (12 in./ft.)3 = 0.16 ft3
Total Weight (WT) = ρw x Volumetotal = 29.74 x 0.17 = 5.1 lbs
Self Weight (WS) = ρw x Volumespan = 29.74 x 0.16 = 4.6 lbs
Distributed Self Weight (ws) = = 3.49 plf
540 plf
170 plf
ws = 3.49 plf
1.33 ft.
1.21 ft.
1.46 ft.
520.13 lbs
520.13 lbs
7/16/2021 3
Fby' = (1400)(1.15)(1)(1)(1)(1)(1.2)(1)(1) = 1932.0 psi
fb = = 450.8 psi
 fb = 450.8 psi < Fby' = 1932.0 psi  (CSI = 0.23)   ➜  OK
7/16/2021 4
Fvy' = (150)(1.15)(1)(1)(1) = 172.50 psi
fv* = = 34.34 psi
 fv* = 34.34 psi < Fvy' = 172.50 psi  (CSI = 0.20)   ➜  OK
fv = = 42.27 psi
 fv = 42.27 psi < Fvy' = 172.50 psi  (CSI = 0.25)   ➜  OK
7/16/2021 5
ΔLL = = 0.01 in.
(L/d)LL = 16.00 / 0.01 = 2111
 ΔLL = 0.01 in = L/2111 < L/360   ➜  OK
ΔTL = = 0.01 in.
(L/d)TL = 16.00 / 0.01 = 1598
 ΔTL = 0.01 in = L/1598 < L/240   ➜  OK
Fc⊥y' = (405)(1)(1)(1) = 405.00 psi
Ab = d x lb = 11.25 x 1.5 = 16.88 in2
fc⊥ = = 30.8 psi
 fc⊥ = 30.8 psi < Fc⊥y' = 405.00 psi  (CSI = 0.08)   ➜  OK
7/16/2021 6
