Grade: 24F-E4 1.8E DF/DF
Size: 5.125 x 9
Design Span (L): 19.75 ft.
Clear Span: 19.50 ft.
Total Span: 20.00 ft.
Selfweight: 213.6 lbs
Dist. Selfweight: 10.81 plf
Total Weight: 216.3 lbs
Beam Design 2021A406
7/14/2021 1
b = 5.125 in.
d = 9.000 in.
A = 5.125 x 9.000 = 46.13 in.2
Sx = (5.125)(9.000)2/6 = 69.19 in.3
Sy = (5.125)2(9.000)/6 = 39.40 in.3
Ix = (5.125)(9.000)3/12 = 311.34 in.4
Iy = (5.125)3(9.000)/12 = 100.96 in.4
24F-E4 1.8E DF/DF 2400 1450 650 265 1800000 950000 1400 560 230 1700000 900000 1100 1700 0.5
7/14/2021 2
Volumetotal = N[A x (L + lb)] = 1 x [46.13 x (237.00 + 3)] x (12 in./ft.)3 = 6.41 ft3
Volumespan = N[A x L] = 1 x [46.13 x 237.00] x (12 in./ft.)3 = 6.33 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 6.41 = 216.3 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 6.33 = 213.6 lbs
Distributed Self Weight (ws) = = 10.81 plf
  ws = 10.81 plf
19.75 ft.
19.50 ft.
1858.14 lbs
1858.14 lbs
7/14/2021 3
fb = = 1571.4 psi
 fb = 1571.4 psi < Fbx' = 2760.0 psi  (CSI = 0.57)   ➜  OK
7/14/2021 4
fv* = = 55.14 psi
 fv* = 55.14 psi < Fvx' = 304.75 psi  (CSI = 0.18)   ➜  OK
fv = = 59.67 psi
 fv = 59.67 psi < Fvx' = 304.75 psi  (CSI = 0.20)   ➜  OK
7/14/2021 5
ΔLL = = 0.61 in.
(L/d)LL = 237.00 / 0.61 = 388
 ΔLL = 0.61 in = L/388 < L/360   ➜  OK
ΔTL = = 1.14 in.
(L/d)TL = 237.00 / 1.14 = 209
 ΔTL = 1.14 in = L/209 > L/240   ➜  NG
fc⊥ = = 120.9 psi
 fc⊥ = 120.9 psi < Fc⊥x' = 650.00 psi  (CSI = 0.19)   ➜  OK
7/14/2021 6
