Size: 6.75 x 15
Design Span (L): 13.54 ft.
Clear Span: 13.08 ft.
Total Span: 14.00 ft.
Bearing (lb): 5.5 in.
Live Load: 7350 lbs
Dead Load: 2940 lbs
Selfweight: 321.5 lbs
Dist. Selfweight: 23.74 plf
Total Weight: 332.3 lbs
CV Volume Factor 0.994b - - - - -
Beam Design 2021A403
7/9/2021 1
b = 6.750 in.
d = 15.000 in.
A = 6.750 x 15.000 = 101.25 in.2
Sx = (6.750)(15.000)2/6 = 253.13 in.3
Sy = (6.750)2(15.000)/6 = 113.91 in.3
Ix = (6.750)(15.000)3/12 = 1898.44 in.4
Iy = (6.750)3(15.000)/12 = 384.43 in.4
7/9/2021 2
Volumetotal = N[A x (L + lb)] = 1 x [101.25 x (162.50 + 5.5)] x (12 in./ft.)3 = 9.84 ft3
Volumespan = N[A x L] = 1 x [101.25 x 162.50] x (12 in./ft.)3 = 9.52 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 9.84 = 332.3 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 9.52 = 321.5 lbs
Distributed Self Weight (ws) = = 23.74 plf
7350 lbs
2940 lbs
  ws = 23.74 plf
13.54 ft.
13.08 ft.
5311.17 lbs
5311.17 lbs
7/9/2021 3
CV = = 0.994
CV = 0.994 < CL = 1
Fbx' = (2400)(1.15)(1)(1)(0.994) = 2743.5 psi
fb = = 1677.3 psi
 fb = 1677.3 psi < Fbx' = 2743.5 psi  (CSI = 0.61)   ➜  OK
7/9/2021 4
fv* = = 78.16 psi
 fv* = 78.16 psi < Fvx' = 304.75 psi  (CSI = 0.26)   ➜  OK
fv = = 78.60 psi
 fv = 78.60 psi < Fvx' = 304.75 psi  (CSI = 0.26)   ➜  OK
7/9/2021 5
ΔLL =   =   = 0.19 in.
(L/d)LL = 162.50 / 0.19 = 845
 ΔLL = 0.19 in = L/845 < L/360   ➜  OK
ΔTL =   =   = 0.27 in.
(L/d)TL = 162.50 / 0.27 = 592
 ΔTL = 0.27 in = L/592 < L/240   ➜  OK
Ab = b x lb = 6.75 x 5.5 = 37.13 in2
fc⊥ = = 143.1 psi
 fc⊥ = 143.1 psi < Fc⊥x' = 650.00 psi  (CSI = 0.22)   ➜  OK
7/9/2021 6
