Size: 6.75 x 13.5
Design Span (L): 18.33 ft.
Clear Span: 18.00 ft.
Total Span: 18.67 ft.
Bearing (lb): 4 in.
Live Load: 320 plf
Dead Load: 200 plf
Selfweight: 391.7 lbs
Dist. Selfweight: 21.36 plf
Total Weight: 398.8 lbs
CV Volume Factor 0.975b - - - - -
Beam Design 2021A401
7/6/2021 1
b = 6.750 in.
d = 13.500 in.
A = 6.750 x 13.500 = 91.13 in.2
Sx = (6.750)(13.500)2/6 = 205.03 in.3
Sy = (6.750)2(13.500)/6 = 102.52 in.3
Ix = (6.750)(13.500)3/12 = 1383.96 in.4
Iy = (6.750)3(13.500)/12 = 345.99 in.4
7/6/2021 2
Volumetotal = N[A x (L + lb)] = 1 x [91.13 x (220.00 + 4)] x (12 in./ft.)3 = 11.81 ft3
Volumespan = N[A x L] = 1 x [91.13 x 220.00] x (12 in./ft.)3 = 11.60 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 11.81 = 398.8 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 11.60 = 391.7 lbs
Distributed Self Weight (ws) = = 21.36 plf
320 plf
200 plf
  ws = 21.36 plf
18.33 ft.
18.00 ft.
18.67 ft.
5052.65 lbs
5052.65 lbs
7/6/2021 3
CV = = 0.975
CV = 0.975 < CL = 1
Fbx' = (2400)(1.15)(1)(0.8)(0.975) = 2151.9 psi
fb = = 1331.2 psi
 fb = 1331.2 psi < Fbx' = 2151.9 psi  (CSI = 0.62)   ➜  OK
7/6/2021 4
Fvx' = (265)(1.15)(1)(0.8) = 243.80 psi
fv* = = 71.66 psi
 fv* = 71.66 psi < Fvx' = 243.80 psi  (CSI = 0.29)   ➜  OK
fv = = 81.69 psi
 fv = 81.69 psi < Fvx' = 243.80 psi  (CSI = 0.34)   ➜  OK
7/6/2021 5
ΔLL = = 0.36 in.
(L/d)LL = 220.00 / 0.36 = 606
 ΔLL = 0.36 in = L/606 < L/180   ➜  OK
ΔTL = = 0.61 in.
(L/d)TL = 220.00 / 0.61 = 358
 ΔTL = 0.61 in = L/358 < L/120   ➜  OK
Ab = b x lb = 6.75 x 4 = 27.00 in2
fc⊥ = = 187.1 psi
 fc⊥ = 187.1 psi < Fc⊥x' = 520.00 psi  (CSI = 0.36)   ➜  OK
7/6/2021 6
