Size: 6.75 x 16.5
Design Span (L): 18.00 ft.
Clear Span: 17.50 ft.
Total Span: 18.50 ft.
Live Load: 1320 plf
Dead Load: 100 plf
Selfweight: 470.0 lbs
Dist. Selfweight: 26.11 plf
Total Weight: 483.1 lbs
CV Volume Factor 0.957b - - - - -
Beam Design GWE L9
1/14/2021 1
b = 6.750 in.
d = 16.500 in.
A = 6.750 x 16.500 = 111.38 in.2
Sx = (6.750)(16.500)2/6 = 306.28 in.3
Sy = (6.750)2(16.500)/6 = 125.30 in.3
Ix = (6.750)(16.500)3/12 = 2526.82 in.4
Iy = (6.750)3(16.500)/12 = 422.88 in.4
Beam Design GWE L9
1/14/2021 2
Volumetotal = N[A x (L + lb)] = 1 x [111.38 x (216.00 + 6)] x (12 in./ft.)3 = 14.31 ft3
Volumespan = N[A x L] = 1 x [111.38 x 216.00] x (12 in./ft.)3 = 13.92 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 14.31 = 483.1 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 13.92 = 470.0 lbs
Distributed Self Weight (ws) = = 26.11 plf
1320 plf
  ws = 26.11 plf
18.00 ft.
17.50 ft.
18.50 ft.
13376.54 lbs
13376.54 lbs
Beam Design GWE L9
1/14/2021 3
CV = = 0.957
CV = 0.957 < CL = 1
Fbx' = (2400)(1.15)(1)(1)(0.957) = 2641.3 psi
fb = = 2294.7 psi
 fb = 2294.7 psi < Fbx' = 2641.3 psi  (CSI = 0.87)   ➜  OK
Beam Design GWE L9
1/14/2021 4
fv* = = 148.51 psi
 fv* = 148.51 psi < Fvx' = 304.75 psi  (CSI = 0.49)   ➜  OK
fv = = 175.29 psi
 fv = 175.29 psi < Fvx' = 304.75 psi  (CSI = 0.58)   ➜  OK
Beam Design GWE L9
1/14/2021 5
ΔLL = = 0.69 in.
(L/d)LL = 216.00 / 0.69 = 315
 ΔLL = 0.69 in = L/315 > L/360   ➜  NG
ΔTL = = 0.75 in.
(L/d)TL = 216.00 / 0.75 = 288
 ΔTL = 0.75 in = L/288 < L/240   ➜  OK
fc⊥ = = 330.3 psi
 fc⊥ = 330.3 psi < Fc⊥x' = 650.00 psi  (CSI = 0.51)   ➜  OK
Beam Design GWE L9
1/14/2021 6
