Design Span (L): 8.00 ft.
Clear Span: 7.75 ft.
Total Span: 8.25 ft.
Quantity (N): 10
Live Load: 40 plf
Dead Load: 10 plf
Selfweight: 214.3 lbs
Dist. Selfweight: 26.79 plf
Total Weight: 221.0 lbs
Orientation: Horizontal
Incised Lumber: Yes
Beam Design 2021A393
7/2/2021 1
7/2/2021 2
Volumetotal = N[A x (L + lb)] = 10 x [10.88 x (96.00 + 3)] x (12 in./ft.)3 = 6.23 ft3
Volumespan = N[A x L] = 10 x [10.88 x 96.00] x (12 in./ft.)3 = 6.04 ft3
Total Weight (WT) = ρw x Volumetotal = 35.47 x 6.23 = 221.0 lbs
Self Weight (WS) = ρw x Volumespan = 35.47 x 6.04 = 214.3 lbs
Distributed Self Weight (ws) = = 26.79 plf
40 plf
10 plf
ws = 26.79 plf
7.75 ft.
8.25 ft.
316.74 lbs
316.74 lbs
7/2/2021 3
Fby' = (900)(1.00)(1)(1)(1)(1.2)(1.15)(0.8)(1.15) = 1142.6 psi
fb = = 271.1 psi
 fb = 271.1 psi < Fby' = 1142.6 psi  (CSI = 0.24)   ➜  OK
7/2/2021 4
Fvy' = (180)(1.00)(0.97)(1)(0.8) = 139.68 psi
fv* = = 4.10 psi
 fv* = 4.10 psi < Fvy' = 139.68 psi  (CSI = 0.03)   ➜  OK
fv = = 4.24 psi
 fv = 4.24 psi < Fvy' = 139.68 psi  (CSI = 0.03)   ➜  OK
Ey' = Ey(CM)(Ct)(Ci) = 1600000(0.9)(1)(0.95) = 1368000 psi
7/2/2021 5
ΔLL = = 0.13 in.
(L/d)LL = 96.00 / 0.13 = 726
 ΔLL = 0.13 in = L/726 < L/360   ➜  OK
ΔTL = = 0.25 in.
(L/d)TL = 96.00 / 0.25 = 378
 ΔTL = 0.25 in = L/378 < L/240   ➜  OK
Fc⊥y' = (625)(0.67)(1)(1) = 418.75 psi
Ab = d x lb = 7.25 x 3 = 21.75 in2
fc⊥ = = 1.5 psi
 fc⊥ = 1.5 psi < Fc⊥y' = 418.75 psi  (CSI = 0.00)   ➜  OK
7/2/2021 6
