Design Span (L): 11.29 ft.
Clear Span: 10.83 ft.
Total Span: 11.75 ft.
Bearing (lb): 5.5 in.
Live Load: 320 plf
Dead Load: 80 plf
Selfweight: 93.9 lbs
Dist. Selfweight: 8.31 plf
Total Weight: 97.7 lbs
Orientation: Horizontal
Incised Lumber: Yes
Beam Design 2021A392
7/2/2021 1
7/2/2021 2
Volumetotal = N[A x (L + lb)] = 2 x [16.88 x (135.50 + 5.5)] x (12 in./ft.)3 = 2.75 ft3
Volumespan = N[A x L] = 2 x [16.88 x 135.50] x (12 in./ft.)3 = 2.65 ft3
Total Weight (WT) = ρw x Volumetotal = 35.47 x 2.75 = 97.7 lbs
Self Weight (WS) = ρw x Volumespan = 35.47 x 2.65 = 93.9 lbs
Distributed Self Weight (ws) = = 8.31 plf
320 plf
80 plf
ws = 8.31 plf
11.29 ft.
10.83 ft.
2398.90 lbs
2398.90 lbs
7/2/2021 3
Fby' = (900)(1.00)(1)(1)(1)(1)(1.2)(0.8)(1) = 864.0 psi
fb = = 9255.8 psi
 fb = 9255.8 psi > Fby' = 864.0 psi  (CSI = 10.71)   ➜  NG
7/2/2021 4
Fvy' = (180)(1.00)(0.97)(1)(0.8) = 139.68 psi
fv* = = 100.19 psi
 fv* = 100.19 psi < Fvy' = 139.68 psi  (CSI = 0.72)   ➜  OK
fv = = 102.46 psi
 fv = 102.46 psi < Fvy' = 139.68 psi  (CSI = 0.73)   ➜  OK
Ey' = Ey(CM)(Ct)(Ci) = 1600000(0.9)(1)(0.95) = 1368000 psi
7/2/2021 5
ΔLL = = 13.52 in.
(L/d)LL = 135.50 / 13.52 = 10
 ΔLL = 13.52 in = L/10 > L/360   ➜  NG
ΔTL = = 17.25 in.
(L/d)TL = 135.50 / 17.25 = 8
 ΔTL = 17.25 in = L/8 > L/240   ➜  NG
Fc⊥y' = (625)(0.67)(1)(1) = 418.75 psi
Ab = d x lb = 11.25 x 5.5 = 61.88 in2
fc⊥ = = 19.4 psi
 fc⊥ = 19.4 psi < Fc⊥y' = 418.75 psi  (CSI = 0.05)   ➜  OK
7/2/2021 6
