Size: 6.75 x 22.5
Design Span (L): 18.00 ft.
Clear Span: 17.50 ft.
Total Span: 18.50 ft.
Live Load: 1500 plf
Dead Load: 100 plf
Selfweight: 640.9 lbs
Dist. Selfweight: 35.61 plf
Total Weight: 658.7 lbs
CV Volume Factor 0.928b - - - - -
Beam Design GWE L9
1/14/2021 1
b = 6.750 in.
d = 22.500 in.
A = 6.750 x 22.500 = 151.88 in.2
Sx = (6.750)(22.500)2/6 = 569.53 in.3
Sy = (6.750)2(22.500)/6 = 170.86 in.3
Ix = (6.750)(22.500)3/12 = 6407.23 in.4
Iy = (6.750)3(22.500)/12 = 576.65 in.4
Beam Design GWE L9
1/14/2021 2
Volumetotal = N[A x (L + lb)] = 1 x [151.88 x (216.00 + 6)] x (12 in./ft.)3 = 19.51 ft3
Volumespan = N[A x L] = 1 x [151.88 x 216.00] x (12 in./ft.)3 = 18.98 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 19.51 = 658.7 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 18.98 = 640.9 lbs
Distributed Self Weight (ws) = = 35.61 plf
1500 plf
  ws = 35.61 plf
18.00 ft.
17.50 ft.
18.50 ft.
15129.37 lbs
15129.37 lbs
Beam Design GWE L9
1/14/2021 3
CV = = 0.928
CV = 0.928 < CL = 1
Fbx' = (2400)(1.15)(1)(1)(0.928) = 2560.6 psi
fb = = 1395.7 psi
 fb = 1395.7 psi < Fbx' = 2560.6 psi  (CSI = 0.55)   ➜  OK
Beam Design GWE L9
1/14/2021 4
fv* = = 115.10 psi
 fv* = 115.10 psi < Fvx' = 304.75 psi  (CSI = 0.38)   ➜  OK
fv = = 145.39 psi
 fv = 145.39 psi < Fvx' = 304.75 psi  (CSI = 0.48)   ➜  OK
Beam Design GWE L9
1/14/2021 5
ΔLL = = 0.31 in.
(L/d)LL = 216.00 / 0.31 = 703
 ΔLL = 0.31 in = L/703 < L/360   ➜  OK
ΔTL = = 0.33 in.
(L/d)TL = 216.00 / 0.33 = 645
 ΔTL = 0.33 in = L/645 < L/240   ➜  OK
fc⊥ = = 373.6 psi
 fc⊥ = 373.6 psi < Fc⊥x' = 650.00 psi  (CSI = 0.57)   ➜  OK
Beam Design GWE L9
1/14/2021 6
