Selfweight: 38.7 lbs
Dist. Selfweight: 3.30 plf
Total Weight: 39.5 lbs
CL Beam Stability Factor 0.827 - - - - -
Beam Design 2021A389
7/1/2021 1
7/1/2021 2
ws = 3.30 plf
1069.77 lbs
1069.77 lbs
7/1/2021 3
lu = Unbraced Length = 6 ft.
lu/d = = 7.78
le = 1.63lu + 3d = 1.63(72.0) + 3(9.25) = 145.11 in. = 12.09 ft.  (NDS Table 3.3.3)
Rb = = 24.42
 Rb = 24.42 < 50   ➜  OK
7/1/2021 4
FbE = = 1166.68 psi
Fbx* = Fbx(CD)(CM)(Ct)(CF)(Ci)(Cr) = (900)(1.15)(1)(1)(1.1)(1)(1) = 1138.50 psi
CL =   = 0.827
Fbx' = (900)(1.15)(1)(1)(0.827)(1.1)(1)(1) = 941.6 psi
fb = = 1726.2 psi
 fb = 1726.2 psi > Fbx' = 941.6 psi  (CSI = 1.83)   ➜  NG
fv* = = 98.38 psi
fv = = 113.24 psi
7/1/2021 5
ΔLL = = 0.27 in.
(L/d)LL = 141.00 / 0.27 = 520
 ΔLL = 0.27 in = L/520 < L/180   ➜  OK
ΔTL = = 0.48 in.
(L/d)TL = 141.00 / 0.48 = 292
 ΔTL = 0.48 in = L/292 < L/120   ➜  OK
fc⊥ = = 237.7 psi
7/1/2021 6
