Size: 3.5 x 12
Design Span (L): 42.00 ft.
Clear Span: 41.50 ft.
Total Span: 42.50 ft.
Quantity (N): 5
Live Load: 2000 lbs
Dead Load: 75 lbs
Selfweight: 2172.4 lbs
Dist. Selfweight: 51.72 plf
Total Weight: 2198.2 lbs
Load Duration: 1.60
CV Volume Factor 0.969b - - - - -
Beam Design Joe Frechette Corvallis MT 2021A387
6/30/2021 1
6/30/2021 2
Volumetotal = N[A x (L + lb)] = 5 x [42.00 x (504.00 + 6)] x (12 in./ft.)3 = 61.98 ft3
Volumespan = N[A x L] = 5 x [42.00 x 504.00] x (12 in./ft.)3 = 61.25 ft3
Total Weight (WT) = ρw x Volumetotal = 35.47 x 61.98 = 2198.2 lbs
Self Weight (WS) = ρw x Volumespan = 35.47 x 61.25 = 2172.4 lbs
Distributed Self Weight (ws) = = 51.72 plf
2000 lbs
75 lbs
  ws = 51.72 plf
42.00 ft.
41.50 ft.
42.50 ft.
2136.61 lbs
2136.61 lbs
6/30/2021 3
CV = = 0.969
CV = 0.969 < CL = 1
Fbx' = (2400)(1.60)(0.8)(1)(0.969) = 2977.7 psi
fb = = 948.4 psi
 fb = 948.4 psi < Fbx' = 2977.7 psi  (CSI = 0.32)   ➜  OK
6/30/2021 4
Fvx' = (265)(1.60)(0.875)(1) = 371.00 psi
fv* = = 14.80 psi
 fv* = 14.80 psi < Fvx' = 371.00 psi  (CSI = 0.04)   ➜  OK
fv = = 15.17 psi
 fv = 15.17 psi < Fvx' = 371.00 psi  (CSI = 0.04)   ➜  OK
6/30/2021 5
ΔLL =   =   = 1.41 in.
(L/d)LL = 504.00 / 1.41 = 357
 ΔLL = 1.41 in = L/357 < L/180   ➜  OK
ΔTL =   =   = 2.42 in.
(L/d)TL = 504.00 / 2.42 = 208
 ΔTL = 2.42 in = L/208 < L/120   ➜  OK
fc⊥ = = 20.3 psi
 fc⊥ = 20.3 psi < Fc⊥x' = 344.50 psi  (CSI = 0.06)   ➜  OK
6/30/2021 6
