Beam Design - load assessment
Grade: SP DSS
Size: 4 x 6
Design Span (L): 8.54 ft.
Clear Span: 8.25 ft.
Total Span: 8.83 ft.
Bearing (lb): 3.5 in.
Live Load: 60 plf
Dead Load: 91 plf
Selfweight: 42.6 lbs
Dist. Selfweight: 4.99 plf
Total Weight: 44.1 lbs
Defl. Limits: 480|360
Load Duration: 1.60
Beam Design Heather Chapman 1577 Merkle St Honolulu HI 11465
6/21/2021 1
SP DSS 2400 1650 175 660 1900 1900000 690000 0.55
6/21/2021 2
Volumetotal = N[A x (L + lb)] = 1 x [19.25 x (102.46 + 3.5)] x (12 in./ft.)3 = 1.18 ft3
Volumespan = N[A x L] = 1 x [19.25 x 102.46] x (12 in./ft.)3 = 1.14 ft3
Total Weight (WT) = ρw x Volumetotal = 37.33 x 1.18 = 44.1 lbs
Self Weight (WS) = ρw x Volumespan = 37.33 x 1.14 = 42.6 lbs
Distributed Self Weight (ws) = = 4.99 plf
60 plf
91 plf
ws = 4.99 plf
8.54 ft.
8.25 ft.
8.83 ft.
688.67 lbs
688.67 lbs
6/21/2021 3
Fbx' = (2400)(1.60)(1)(1)(1)(1)(1)(1) = 3840.0 psi
fb = = 966.6 psi
 fb = 966.6 psi < Fbx' = 3840.0 psi  (CSI = 0.25)   ➜  OK
6/21/2021 4
Fvx' = (175)(1.60)(1)(1)(1) = 280.00 psi
fv* = = 46.32 psi
 fv* = 46.32 psi < Fvx' = 280.00 psi  (CSI = 0.17)   ➜  OK
fv = = 51.89 psi
 fv = 51.89 psi < Fvx' = 280.00 psi  (CSI = 0.19)   ➜  OK
LL Allowable: L/480
TL Allowable: L/360
6/21/2021 5
ΔLL = = 0.08 in.
(L/d)LL = 102.46 / 0.08 = 1317
 ΔLL = 0.08 in = L/1317 < L/480   ➜  OK
ΔTL = = 0.20 in.
(L/d)TL = 102.46 / 0.20 = 506
 ΔTL = 0.20 in = L/506 < L/360   ➜  OK
fc⊥ = = 56.2 psi
 fc⊥ = 56.2 psi < Fc⊥x' = 660.00 psi  (CSI = 0.09)   ➜  OK
6/21/2021 6
