Design Span (L): 12.29 ft.
Clear Span: 12.00 ft.
Total Span: 12.58 ft.
Bearing (lb): 3.5 in.
Live Load: 10 plf
Dead Load: 25 plf
Selfweight: 48.2 lbs
Dist. Selfweight: 3.92 plf
Total Weight: 49.3 lbs
Beam Design 2021A375
6/20/2021 1
6/20/2021 2
Volumetotal = N[A x (L + lb)] = 2 x [8.25 x (147.50 + 3.5)] x (12 in./ft.)3 = 1.44 ft3
Volumespan = N[A x L] = 2 x [8.25 x 147.50] x (12 in./ft.)3 = 1.41 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 1.44 = 49.3 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 1.41 = 48.2 lbs
10 plf
25 plf
ws = 3.92 plf
12.29 ft.
12.58 ft.
244.87 lbs
244.87 lbs
6/20/2021 3
lu/d = = 4.36
Rb = = 5.50
 Rb = 5.50 < 50   ➜  OK
6/20/2021 4
FbE = = 23036.19 psi
Fbx* = Fbx(CD)(CM)(Ct)(CF)(Ci)(Cr) = (900)(1.15)(1)(1)(1.3)(1)(1) = 1345.50 psi
CL =   = 0.997
Fbx' = (900)(1.15)(1)(1)(0.997)(1.3)(1)(1) = 1341.4 psi
fb = = 583.2 psi
 fb = 583.2 psi < Fbx' = 1341.4 psi  (CSI = 0.43)   ➜  OK
fv* = = 20.12 psi
 fv* = 20.12 psi < Fvx' = 207.00 psi  (CSI = 0.10)   ➜  OK
fv = = 21.75 psi
 fv = 21.75 psi < Fvx' = 207.00 psi  (CSI = 0.11)   ➜  OK
6/20/2021 5
ΔLL = = 0.08 in.
(L/d)LL = 147.50 / 0.08 = 1911
 ΔLL = 0.08 in = L/1911 < L/360   ➜  OK
ΔTL = = 0.30 in.
(L/d)TL = 147.50 / 0.30 = 491
 ΔTL = 0.30 in = L/491 < L/240   ➜  OK
fc⊥ = = 23.3 psi
 fc⊥ = 23.3 psi < Fc⊥x' = 625.00 psi  (CSI = 0.04)   ➜  OK
6/20/2021 6
