Grade: SPF No.2
Design Span (L): 29.75 ft.
Clear Span: 29.50 ft.
Total Span: 30.00 ft.
Quantity (N): 4
Selfweight: 405.8 lbs
Dist. Selfweight: 13.64 plf
Total Weight: 409.2 lbs
Beam Design 2021A373
6/20/2021 1
6/20/2021 2
Volumetotal = N[A x (L + lb)] = 4 x [16.88 x (357.00 + 3)] x (12 in./ft.)3 = 14.06 ft3
Volumespan = N[A x L] = 4 x [16.88 x 357.00] x (12 in./ft.)3 = 13.95 ft3
Total Weight (WT) = ρw x Volumetotal = 29.10 x 14.06 = 409.2 lbs
Self Weight (WS) = ρw x Volumespan = 29.10 x 13.95 = 405.8 lbs
Distributed Self Weight (ws) = = 13.64 plf
ws = 13.64 plf
29.75 ft.
29.50 ft.
30.00 ft.
2829.59 lbs
2829.59 lbs
6/20/2021 3
Fbx' = (875)(1.00)(1)(1)(1)(1)(1)(1) = 875.0 psi
fb = = 1978.8 psi
 fb = 1978.8 psi > Fbx' = 875.0 psi  (CSI = 2.26)   ➜  NG
6/20/2021 4
fv* = = 58.43 psi
 fv* = 58.43 psi < Fvx' = 135.00 psi  (CSI = 0.43)   ➜  OK
fv = = 62.36 psi
 fv = 62.36 psi < Fvx' = 135.00 psi  (CSI = 0.46)   ➜  OK
6/20/2021 5
ΔLL = = 1.77 in.
(L/d)LL = 357.00 / 1.77 = 202
 ΔLL = 1.77 in = L/202 > L/360   ➜  NG
ΔTL = = 3.34 in.
(L/d)TL = 357.00 / 3.34 = 107
 ΔTL = 3.34 in = L/107 > L/240   ➜  NG
fc⊥ = = 157.2 psi
 fc⊥ = 157.2 psi < Fc⊥x' = 425.00 psi  (CSI = 0.37)   ➜  OK
6/20/2021 6
