Grade: DF SS
Design Span (L): 29.75 ft.
Clear Span: 29.50 ft.
Total Span: 30.00 ft.
Selfweight: 119.2 lbs
Dist. Selfweight: 4.01 plf
Total Weight: 120.2 lbs
CL Beam Stability Factor 0.238 - - - - -
Beam Design 2021A372
6/17/2021 1
6/17/2021 2
Volumetotal = N[A x (L + lb)] = 1 x [16.88 x (357.00 + 3)] x (12 in./ft.)3 = 3.52 ft3
Volumespan = N[A x L] = 1 x [16.88 x 357.00] x (12 in./ft.)3 = 3.49 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 3.52 = 120.2 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 3.49 = 119.2 lbs
ws = 4.01 plf
29.75 ft.
29.50 ft.
30.00 ft.
2685.12 lbs
2685.12 lbs
6/17/2021 3
lu = Unbraced Length = 18 ft.
lu/d = = 19.20
le = 1.84lu = 1.84(216.0) = 397.44 in. = 33.12 ft.  (NDS Table 3.3.3)
Rb = = 44.58
 Rb = 44.58 < 50   ➜  OK
6/17/2021 4
FbE = = 416.67 psi
Fbx* = Fbx(CD)(CM)(Ct)(CF)(Ci)(Cr) = (1500)(1.15)(1)(1)(1)(1)(1) = 1725.00 psi
CL =   = 0.238
Fbx' = (1500)(1.15)(1)(1)(0.238)(1)(1)(1) = 410.3 psi
fb = = 7510.9 psi
 fb = 7510.9 psi > Fbx' = 410.3 psi  (CSI = 18.31)   ➜  NG
fv* = = 221.77 psi
 fv* = 221.77 psi > Fvx' = 207.00 psi  (CSI = 1.07)   ➜  NG
fv = = 236.69 psi
 fv = 236.69 psi > Fvx' = 207.00 psi  (CSI = 1.14)   ➜  NG
6/17/2021 5
ΔLL = = 5.21 in.
(L/d)LL = 357.00 / 5.21 = 68
 ΔLL = 5.21 in = L/68 > L/180   ➜  NG
ΔTL = = 9.33 in.
(L/d)TL = 357.00 / 9.33 = 38
 ΔTL = 9.33 in = L/38 > L/120   ➜  NG
fc⊥ = = 596.7 psi
 fc⊥ = 596.7 psi < Fc⊥x' = 625.00 psi  (CSI = 0.95)   ➜  OK
6/17/2021 6
