Grade: 24F-V3 1.8E SP/SP
Size: 2.5 x 5.5
Design Span (L): 16.25 ft.
Clear Span: 16.00 ft.
Total Span: 16.50 ft.
Selfweight: 57.2 lbs
Dist. Selfweight: 3.52 plf
Total Weight: 58.1 lbs
Beam Design 2021A369
6/15/2021 1
b = 2.500 in.
A = 2.500 x 5.500 = 13.75 in.2
Sx = (2.500)(5.500)2/6 = 12.60 in.3
Sy = (2.500)2(5.500)/6 = 5.73 in.3
Ix = (2.500)(5.500)3/12 = 34.66 in.4
Iy = (2.500)3(5.500)/12 = 7.16 in.4
6/15/2021 2
= 36.89 lbs/ft3
Volumetotal = N[A x (L + lb)] = 1 x [13.75 x (195.00 + 3)] x (12 in./ft.)3 = 1.58 ft3
Volumespan = N[A x L] = 1 x [13.75 x 195.00] x (12 in./ft.)3 = 1.55 ft3
Total Weight (WT) = ρw x Volumetotal = 36.89 x 1.58 = 58.1 lbs
Self Weight (WS) = ρw x Volumespan = 36.89 x 1.55 = 57.2 lbs
  ws = 3.52 plf
16.25 ft.
16.50 ft.
1472.81 lbs
1472.81 lbs
6/15/2021 3
fb = = 5610.2 psi
 fb = 5610.2 psi > Fbx' = 2760.0 psi  (CSI = 2.03)   ➜  NG
6/15/2021 4
fv* = = 149.31 psi
 fv* = 149.31 psi < Fvx' = 345.00 psi  (CSI = 0.43)   ➜  OK
fv = = 158.24 psi
 fv = 158.24 psi < Fvx' = 345.00 psi  (CSI = 0.46)   ➜  OK
6/15/2021 5
ΔLL = = 2.51 in.
(L/d)LL = 195.00 / 2.51 = 78
 ΔLL = 2.51 in = L/78 > L/180   ➜  NG
ΔTL = = 4.49 in.
(L/d)TL = 195.00 / 4.49 = 43
 ΔTL = 4.49 in = L/43 > L/120   ➜  NG
fc⊥ = = 196.4 psi
 fc⊥ = 196.4 psi < Fc⊥x' = 740.00 psi  (CSI = 0.27)   ➜  OK
6/15/2021 6
