Grade: 24F-V8 1.8E DF/DF
Size: 6.75 x 16.5
Design Span (L): 23.75 ft.
Clear Span: 23.50 ft.
Total Span: 24.00 ft.
Live Load: 240 plf
Dead Load: 144 plf
Selfweight: 620.2 lbs
Dist. Selfweight: 26.11 plf
Total Weight: 626.7 lbs
Defl. Limits: 480|360
Load Duration: 1.25
CV Volume Factor 0.931b - - - - -
Beam Design 10098
6/13/2021 1
b = 6.750 in.
d = 16.500 in.
A = 6.750 x 16.500 = 111.38 in.2
Sx = (6.750)(16.500)2/6 = 306.28 in.3
Sy = (6.750)2(16.500)/6 = 125.30 in.3
Ix = (6.750)(16.500)3/12 = 2526.82 in.4
Iy = (6.750)3(16.500)/12 = 422.88 in.4
Beam Design 10098
6/13/2021 2
Volumetotal = N[A x (L + lb)] = 1 x [111.38 x (285.00 + 3)] x (12 in./ft.)3 = 18.56 ft3
Volumespan = N[A x L] = 1 x [111.38 x 285.00] x (12 in./ft.)3 = 18.37 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 18.56 = 626.7 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 18.37 = 620.2 lbs
Distributed Self Weight (ws) = = 26.11 plf
240 plf
144 plf
  ws = 26.11 plf
23.75 ft.
23.50 ft.
24.00 ft.
4921.35 lbs
4921.35 lbs
Beam Design 10098
6/13/2021 3
CV = = 0.931
CV = 0.931 < CL = 1
Fbx' = (2400)(1.25)(1)(1)(0.931) = 2792.5 psi
fb = = 1132.9 psi
 fb = 1132.9 psi < Fbx' = 2792.5 psi  (CSI = 0.41)   ➜  OK
Beam Design 10098
6/13/2021 4
fv* = = 58.00 psi
 fv* = 58.00 psi < Fvx' = 331.25 psi  (CSI = 0.18)   ➜  OK
fv = = 65.59 psi
 fv = 65.59 psi < Fvx' = 331.25 psi  (CSI = 0.20)   ➜  OK
LL Allowable: L/480
TL Allowable: L/360
Beam Design 10098
6/13/2021 5
ΔLL = = 0.38 in.
(L/d)LL = 285.00 / 0.38 = 754
 ΔLL = 0.38 in = L/754 < L/480   ➜  OK
ΔTL = = 0.65 in.
(L/d)TL = 285.00 / 0.65 = 442
 ΔTL = 0.65 in = L/442 < L/360   ➜  OK
fc⊥ = = 243.0 psi
 fc⊥ = 243.0 psi < Fc⊥x' = 650.00 psi  (CSI = 0.37)   ➜  OK
Beam Design 10098
6/13/2021 6
