Size: 3.5 x 10.5
Design Span (L): 17.75 ft.
Clear Span: 17.50 ft.
Total Span: 18.00 ft.
Live Load: 75 plf
Selfweight: 160.7 lbs
Dist. Selfweight: 9.05 plf
Total Weight: 162.9 lbs
Load Duration: 1.25
Beam Design 2021A365
6/11/2021 1
d = 10.500 in.
A = 3.500 x 10.500 = 36.75 in.2
Sx = (3.500)(10.500)2/6 = 64.31 in.3
Sy = (3.500)2(10.500)/6 = 21.44 in.3
Ix = (3.500)(10.500)3/12 = 337.64 in.4
Iy = (3.500)3(10.500)/12 = 37.52 in.4
6/11/2021 2
Volumetotal = N[A x (L + lb)] = 1 x [36.75 x (213.00 + 3)] x (12 in./ft.)3 = 4.59 ft3
Volumespan = N[A x L] = 1 x [36.75 x 213.00] x (12 in./ft.)3 = 4.53 ft3
Total Weight (WT) = ρw x Volumetotal = 35.47 x 4.59 = 162.9 lbs
Self Weight (WS) = ρw x Volumespan = 35.47 x 4.53 = 160.7 lbs
Distributed Self Weight (ws) = = 9.05 plf
  ws = 9.05 plf
17.75 ft.
17.50 ft.
18.00 ft.
1431.46 lbs
1431.46 lbs
6/11/2021 3
Fbx' = (2400)(1.25)(0.8)(1)(1.0) = 2400.0 psi
fb = = 1168.8 psi
 fb = 1168.8 psi < Fbx' = 2400.0 psi  (CSI = 0.49)   ➜  OK
6/11/2021 4
Fvx' = (265)(1.25)(0.875)(1) = 289.84 psi
fv* = = 51.94 psi
 fv* = 51.94 psi < Fvx' = 289.84 psi  (CSI = 0.18)   ➜  OK
fv = = 57.62 psi
 fv = 57.62 psi < Fvx' = 289.84 psi  (CSI = 0.20)   ➜  OK
6/11/2021 5
ΔLL = = 0.33 in.
(L/d)LL = 213.00 / 0.33 = 644
 ΔLL = 0.33 in = L/644 < L/360   ➜  OK
ΔTL = = 0.70 in.
(L/d)TL = 213.00 / 0.70 = 304
 ΔTL = 0.70 in = L/304 < L/240   ➜  OK
fc⊥ = = 136.3 psi
 fc⊥ = 136.3 psi < Fc⊥x' = 344.50 psi  (CSI = 0.40)   ➜  OK
6/11/2021 6
