Beam Design - buxton beam
Design Span (L): 9.75 ft.
Clear Span: 9.50 ft.
Total Span: 10.00 ft.
Live Load: 360 plf
Dead Load: 90 plf
Selfweight: 108.7 lbs
Dist. Selfweight: 11.15 plf
Total Weight: 111.5 lbs
Beam Design 2021A356
6/4/2021 1
6/4/2021 2
= 38.58 lbs/ft3
Volumetotal = N[A x (L + lb)] = 3 x [13.88 x (117.00 + 3)] x (12 in./ft.)3 = 2.89 ft3
Volumespan = N[A x L] = 3 x [13.88 x 117.00] x (12 in./ft.)3 = 2.82 ft3
Total Weight (WT) = ρw x Volumetotal = 38.58 x 2.89 = 111.5 lbs
Self Weight (WS) = ρw x Volumespan = 38.58 x 2.82 = 108.7 lbs
Distributed Self Weight (ws) = = 11.15 plf
360 plf
90 plf
ws = 11.15 plf
9.75 ft.
9.50 ft.
10.00 ft.
2305.76 lbs
2305.76 lbs
6/4/2021 3
fb = = 1024.7 psi
 fb = 1024.7 psi > Fbx' = 920.0 psi  (CSI = 1.11)   ➜  NG
6/4/2021 4
fv* = = 68.20 psi
 fv* = 68.20 psi < Fvx' = 195.21 psi  (CSI = 0.35)   ➜  OK
fv = = 81.01 psi
 fv = 81.01 psi < Fvx' = 195.21 psi  (CSI = 0.42)   ➜  OK
6/4/2021 5
ΔLL = = 0.20 in.
(L/d)LL = 117.00 / 0.20 = 598
 ΔLL = 0.20 in = L/598 < L/360   ➜  OK
ΔTL = = 0.25 in.
(L/d)TL = 117.00 / 0.25 = 467
 ΔTL = 0.25 in = L/467 < L/240   ➜  OK
fc⊥ = = 170.8 psi
 fc⊥ = 170.8 psi < Fc⊥x' = 378.55 psi  (CSI = 0.45)   ➜  OK
6/4/2021 6
