Grade: SP No.1
Design Span (L): 5.75 ft.
Clear Span: 5.50 ft.
Total Span: 6.00 ft.
Live Load: 180 plf
Dead Load: 563 plf
Selfweight: 41.4 lbs
Dist. Selfweight: 7.19 plf
Total Weight: 43.2 lbs
Beam Design 2021A352
5/31/2021 1
5/31/2021 2
Volumetotal = N[A x (L + lb)] = 2 x [13.88 x (69.00 + 3)] x (12 in./ft.)3 = 1.16 ft3
Volumespan = N[A x L] = 2 x [13.88 x 69.00] x (12 in./ft.)3 = 1.11 ft3
Total Weight (WT) = ρw x Volumetotal = 37.33 x 1.16 = 43.2 lbs
Self Weight (WS) = ρw x Volumespan = 37.33 x 1.11 = 41.4 lbs
180 plf
563 plf
ws = 7.19 plf
5.75 ft.
5.50 ft.
2250.58 lbs
2250.58 lbs
5/31/2021 3
Fbx' = (1050)(1.00)(1)(1)(1)(1)(1)(1) = 1050.0 psi
fb = = 869.7 psi
 fb = 869.7 psi < Fbx' = 1050.0 psi  (CSI = 0.83)   ➜  OK
5/31/2021 4
fv* = = 85.33 psi
 fv* = 85.33 psi < Fvx' = 175.00 psi  (CSI = 0.49)   ➜  OK
fv = = 116.58 psi
 fv = 116.58 psi < Fvx' = 175.00 psi  (CSI = 0.67)   ➜  OK
5/31/2021 5
ΔLL = = 0.01 in.
(L/d)LL = 69.00 / 0.01 = 4934
 ΔLL = 0.01 in = L/4934 < L/360   ➜  OK
ΔTL = = 0.06 in.
(L/d)TL = 69.00 / 0.06 = 1184
 ΔTL = 0.06 in = L/1184 < L/240   ➜  OK
fc⊥ = = 250.1 psi
 fc⊥ = 250.1 psi < Fc⊥x' = 565.00 psi  (CSI = 0.44)   ➜  OK
5/31/2021 6
