Beam Design - 6 3/4 X 16.5 85 PSF SL
Size: 6.75 x 16.5
Design Span (L): 17.17 ft.
Clear Span: 16.83 ft.
Total Span: 17.50 ft.
Bearing (lb): 4 in.
Live Load: 1320 plf
Selfweight: 448.3 lbs
Dist. Selfweight: 26.11 plf
Total Weight: 457.0 lbs
CV Volume Factor 0.962b - - - - -
Beam Design B Holmes GWE L9
1/14/2021 1
b = 6.750 in.
d = 16.500 in.
A = 6.750 x 16.500 = 111.38 in.2
Sx = (6.750)(16.500)2/6 = 306.28 in.3
Sy = (6.750)2(16.500)/6 = 125.30 in.3
Ix = (6.750)(16.500)3/12 = 2526.82 in.4
Iy = (6.750)3(16.500)/12 = 422.88 in.4
1/14/2021 2
Volumetotal = N[A x (L + lb)] = 1 x [111.38 x (206.00 + 4)] x (12 in./ft.)3 = 13.54 ft3
Volumespan = N[A x L] = 1 x [111.38 x 206.00] x (12 in./ft.)3 = 13.28 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 13.54 = 457.0 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 13.28 = 448.3 lbs
Distributed Self Weight (ws) = = 26.11 plf
1320 plf
  ws = 26.11 plf
17.17 ft.
16.83 ft.
17.50 ft.
12434.97 lbs
12434.97 lbs
1/14/2021 3
CV = = 0.962
CV = 0.962 < CL = 1
Fbx' = (2400)(1.15)(1)(1)(0.962) = 2653.8 psi
fb = = 2051.1 psi
 fb = 2051.1 psi < Fbx' = 2653.8 psi  (CSI = 0.77)   ➜  OK
1/14/2021 4
fv* = = 137.97 psi
 fv* = 137.97 psi < Fvx' = 304.75 psi  (CSI = 0.45)   ➜  OK
fv = = 164.28 psi
 fv = 164.28 psi < Fvx' = 304.75 psi  (CSI = 0.54)   ➜  OK
1/14/2021 5
ΔLL = = 0.57 in.
(L/d)LL = 206.00 / 0.57 = 363
 ΔLL = 0.57 in = L/363 < L/360   ➜  OK
ΔTL = = 0.61 in.
(L/d)TL = 206.00 / 0.61 = 337
 ΔTL = 0.61 in = L/337 < L/240   ➜  OK
Ab = b x lb = 6.75 x 4 = 27.00 in2
fc⊥ = = 460.6 psi
 fc⊥ = 460.6 psi < Fc⊥x' = 650.00 psi  (CSI = 0.71)   ➜  OK
1/14/2021 6
