Beam Design - CPH Garage Beam Sizing
Grade: 24F-V3 1.8E SP/SP
Size: 5.5 x 16.5
Design Span (L): 12.37 ft.
Clear Span: 12.00 ft.
Total Span: 12.75 ft.
Bearing (lb): 4.5 in.
Live Load: 5898 lbs
Dead Load: 4167 lbs
Selfweight: 287.6 lbs
Dist. Selfweight: 23.25 plf
Total Weight: 296.3 lbs
Notes: Sizing for the garage beam, onto which the westernmost support column for the main roof beam transfers a vertical point load.
Beam Design Steven Rhodes 1302 Tarragon Drive, Marysville OH 43040 CPH2
5/29/2021 1
d = 16.500 in.
5/29/2021 2
= 36.89 lbs/ft3
Volumetotal = N[A x (L + lb)] = 1 x [90.75 x (148.46 + 4.5)] x (12 in./ft.)3 = 8.03 ft3
Volumespan = N[A x L] = 1 x [90.75 x 148.46] x (12 in./ft.)3 = 7.80 ft3
Total Weight (WT) = ρw x Volumetotal = 36.89 x 8.03 = 296.3 lbs
Self Weight (WS) = ρw x Volumespan = 36.89 x 7.80 = 287.6 lbs
Distributed Self Weight (ws) = = 23.25 plf
5898 lbs
4167 lbs
  ws = 23.25 plf
12.37 ft.
12.75 ft.
5180.67 lbs
5180.67 lbs
5/29/2021 3
fb = = 1518.3 psi
 fb = 1518.3 psi < Fbx' = 2760.0 psi  (CSI = 0.55)   ➜  OK
5/29/2021 4
fv* = = 85.03 psi
 fv* = 85.03 psi < Fvx' = 345.00 psi  (CSI = 0.25)   ➜  OK
fv = = 85.56 psi
 fv = 85.56 psi < Fvx' = 345.00 psi  (CSI = 0.25)   ➜  OK
5/29/2021 5
ΔLL =   =   = 0.11 in.
(L/d)LL = 148.46 / 0.11 = 1368
 ΔLL = 0.11 in = L/1368 < L/360   ➜  OK
ΔTL =   =   = 0.19 in.
(L/d)TL = 148.46 / 0.19 = 788
 ΔTL = 0.19 in = L/788 < L/240   ➜  OK
Ab = b x lb = 5.5 x 4.5 = 24.75 in2
fc⊥ = = 209.3 psi
 fc⊥ = 209.3 psi < Fc⊥x' = 740.00 psi  (CSI = 0.28)   ➜  OK
5/29/2021 6
